Plugins 〉Trend Dot
Developer
BT Plc
The Trend Dot plugin has been deprecated and is no longer maintained.
Panel
Trend Dot
  • Overview
  • Installation
  • Related content
Grafana Trend Dot (UNSUPPORTED)
A trend dot panel for Grafana.
This plugin is unsupported. Please try the status dot plugin instead.
Trend Dot Panel
Overview
This panel shows a dot for each series, where each dot is colored based on the percentage change between the first and last values of that series. This is is useful if you want to monitor a collection of values as they change over time. Options for this panel include variable radius, precision and units (for the tooltip) and color thresholds for the percentage change.
Compatibility
This panel should work with the following data sources: Graphite
Development
Docker is an easy way to spin-up an instance of Grafana. With docker installed, run the following command in the directory containing the plugin; this will expose the local plugin on your machine to the Grafana container so you can test it out.
docker run -it -v $PWD:/var/lib/grafana/plugins/trend_dot -p 3000:3000 --name grafana.docker grafana/grafana
Now do this...
# Install development packages
npm install
Install the grunt-cli
sudo npm install -g grunt-cli
Compile into dist/
grunt
Restart Grafana to see it
docker restart grafana.docker
Watch for changes (requires refresh)
grunt watch
Use grunt test to run the Jasmine tests for the plugin; and grunt eslint to check for style issues. Note that the plugin controller isn't tested because it depends on Grafana native libraries, which aren't available outside of Grafana.
Contributing
For bugs and new features, open an issue and we'll take a look. If you want to contribute to the plugin, you're welcome to submit a pull request - just make sure grunt runs without errors first.
Installing Trend Dot on Grafana Cloud:
