title: "Singlestat Math panel plugin for Grafana"
description: "Single Stat panel with math. Singlestat Math panel plugin for Grafana by blackmirror1. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/blackmirror1-singlestat-math-panel/
# Singlestat Math
- Developer: blackmirror1
- Version: 1.1.8
- [Installation](https://grafana.com/grafana/plugins/blackmirror1-singlestat-math-panel/installation.md)
# Single Stat Math Panel
This panel is a modification of the native single stat panel to support math functions across series.
### Usage
### InfluxDB
To use the math feature, give the series an alias by name and use that name inside the math field as variables.
![Image of using InfluxDB metric](https://raw.github.com/black-mirror-1/singlestat-math/master/src/img/readme/influx_metric.png)
In the math field you can use the alias names to perform math across series.
![Image of using math field](https://raw.github.com/black-mirror-1/singlestat-math/master/src/img/readme/math_field.png)
## Changelog
## 1.1.6
- Merged [PR](https://github.com/black-mirror-1/singlestat-math/pull/17) to fix gauge color
## 1.1.5
- Merged [PR](https://github.com/black-mirror-1/singlestat-math/pull/12) to autoupdate panels with previous threshold format.
## 1.1.4
- Merged [PR](https://github.com/black-mirror-1/singlestat-math/pull/9) to add granular threshold options.
## 1.1.3
- Merged [PR](https://github.com/black-mirror-1/singlestat-math/pull/6) to add circle shape as background option.
## 1.1.2
- Merged [PR](https://github.com/black-mirror-1/singlestat-math/pull/5) to remove importing own flot plugins.
## 1.1.1
- Changed function evaluation error handling to set results to zero
## 1.1.0
- Fixed missing flot library crashing graph panel.
- Updated dependencies.
## 1.0.0
- Added math options if multiple queries are used.
- Math field will use series alias name to evaluate function.
