title: "QR code panel plugin for Grafana"
description: "Render a QR code. QR code panel plugin for Grafana by betatech. Available in Grafana Cloud and self-managed Grafana. See install steps and the changelog."
> This is the Markdown version of https://grafana.com/grafana/plugins/betatech-qrcode-panel/
# QR code
- Developer: betatech
- Version: 1.0.0
- [Installation](https://grafana.com/grafana/plugins/betatech-qrcode-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/betatech-qrcode-panel/changelog.md)
![Panel](https://grafana.com/api/plugins/betatech-qrcode-panel/versions/1.0.0/images/img/dashboard.png)
# QRcode
![Dashboard](https://raw.githubusercontent.com/Beta-Technologies/grafana-panel-qrcode/refs/heads/main/src/img/dashboard.png)
## Overview / Introduction
Utilizing the react QR code library, this plugin takes a string and renders it as a QR code. Variable interpolation is implemented.
## Requirements
Grafana >= 9.0.0
## Getting Started
After adding the panel, set the value property to the string to be rendered
## Package
### Build
npm run build
### Generate signature manifest
export GRAFANA_ACCESS_POLICY_TOKEN=<redacted - get from keypasx>
npx @grafana/sign-plugin@latest --rootUrls https://github.com/Beta-Technologies/grafana-panel-qrcode
## Zip / Generate SHA1
mv dist betatech-qrcode-panel
zip betatech-qrcode-panel-1.0.0.zip betatech-qrcode-panel -r
rm -rf betatech-qrcode-panel
shasum betatech-qrcode-panel-1.0.0.zip
### Push latest
git add -A
git commit -m 'new version of plugin'
git push
### Validate
Run validator (save time in automated steps of approval cycle)
docker run --pull=always grafana/plugin-validator-cli https://github.com/Beta-Technologies/grafana-panel-qrcode/raw/refs/heads/main/betatech-qrcode-panel-1.0.0.zip
## License
MIT License, see [LICENSE](https://github.com/Beta-Technologies/grafana-panel-qrcode/blob/main/LICENSE).
