title: "PictureIt panel plugin for Grafana"
description: "Add Measurements to a Picture in Grafana. PictureIt panel plugin for Grafana by bessler. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/bessler-pictureit-panel/
# PictureIt
- Developer: bessler
- Version: 1.0.1
![Showcase](https://grafana.com/api/plugins/bessler-pictureit-panel/versions/1.0.1/images/img/bridge_strains.png)
## PictureIt Panel Plugin for Grafana
Allows a user to superimpose measurement displays ontop of picture.
### PictureIt
1. Enter a URL for your background image.
2. Set up some metrics (Influx and "fake data source" tested).
3. Then add sensor displays ontop of the picture and tie them to the metrics.
![PictureIt](https://raw.githubusercontent.com/vbessler/grafana-pictureit/master/src/img/bridge_strains.png?raw=true)
### Options
Each measurement display is linked to a metric through the metrics name or alias. If the metric returns a series of values then the last values is displayed.
![Options](https://raw.githubusercontent.com/vbessler/grafana-pictureit/master/src/img/settings.png?raw=true)
