title: "Waterfall Panel plugin for Grafana"
description: "A waterfall panel for a single time-series. Waterfall Panel plugin for Grafana by auxmoney-plugins. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/auxmoney-waterfall-panel/
# Waterfall Panel
- Developer: auxmoney-plugins
- Version: 1.0.6
- [Installation](https://grafana.com/grafana/plugins/auxmoney-waterfall-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/auxmoney-waterfall-panel/changelog.md)
![Waterfall example](https://grafana.com/api/plugins/auxmoney-waterfall-panel/versions/1.0.6/images/img/auxmoney-waterfall-panel.png)
This panel is intended to visualize a single time series as a waterfall panel, e.g. to show dependencies between jobs running in parallel in a build pipeline, or a series of HTTP requests.
![Image of a drawn panel](https://github.com/auxmoney/grafana-waterfall-panel/raw/main/src/img/auxmoney-waterfall-panel.png)
# Configuration
After installation, you can add a new panel type "Waterfall Panel" to your dashboards.
## Expected fields
The panel can only handle a single time series, and the time series can consist of these fields:
| field type | required | description         |
| time       | yes      | starting point      |
| number     | yes      | duration in seconds |
| string     | no       | name                |
Make sure you select the fields of the time series as a "Table"!
The time frame will be calculated automatically and creates the panel frame. Each tuple will be represented by a bar in the panel, starting at its "starting point" and taking up space relative to its "duration".
## Display configuration
- "Show inline bar labels" will show the labels inside the bars. The labels are populated from the string field.
  - "Show duration in bar labels" will show the duration in seconds inside the bars.
- "Bar color" is for changing the color of the bars.
- "Value Time Units" is currently hardcoded to "seconds", but will be expanded in future versions.
# Development
Please refer to the [development guide](https://github.com/auxmoney/grafana-waterfall-panel/blob/main/docs/DEVELOPMENT.md).
# Credits
- Icon made from [Icon Fonts](http://www.onlinewebfonts.com/icon) is licensed by CC BY 3.0
