title: "Wazuh data source plugin for Grafana"
description: "Connect Grafana to Wazuh (SIEM/XDR) — query alerts, vulnerabilities, FIM events, SCA compliance scores, and… Wazuh data source plugin for Grafana by armanfeyzi."
> This is the Markdown version of https://grafana.com/grafana/plugins/armanfeyzi-wazuh-datasource/
# Wazuh
- Developer: armanfeyzi
- Version: 0.2.13
- [Installation](https://grafana.com/grafana/plugins/armanfeyzi-wazuh-datasource/installation.md)
- [Change log](https://grafana.com/grafana/plugins/armanfeyzi-wazuh-datasource/changelog.md)
![Security Overview dashboard](https://grafana.com/api/plugins/armanfeyzi-wazuh-datasource/versions/0.2.13/images/img/screenshot-security-overview.png)
![Datasource configuration](https://grafana.com/api/plugins/armanfeyzi-wazuh-datasource/versions/0.2.13/images/img/screenshot-datasource-config.png)
![Explore query editor](https://grafana.com/api/plugins/armanfeyzi-wazuh-datasource/versions/0.2.13/images/img/screenshot-explore-alerts.png)
# Wazuh Datasource for Grafana
Connect Grafana to your Wazuh deployment so security data appears in dashboards and Explore — without manual OpenSearch configuration.
Query **alerts**, **vulnerabilities**, **file integrity monitoring (FIM)**, **SCA compliance**, and **agent status** from Wazuh's manager API and indexer.
## Requirements
- Grafana 10.4 or newer
- Wazuh 4.7 or newer with the manager API and indexer reachable from Grafana
## Getting started
### 1. Install the plugin
In Grafana, go to **Administration → Plugins**, search for **Wazuh**, and click **Install**.
### 2. Add a datasource
1. Go to **Connections → Data sources → Add data source**.
2. Select **Wazuh**.
3. Configure:
   - **Manager URL** — Wazuh manager API base URL (e.g. `https://wazuh.example.com:55000`)
   - **Indexer URL** — Wazuh indexer (OpenSearch) URL (e.g. `https://wazuh-indexer.example.com:9200`)
   - **Username** / **Password** — credentials for the manager API
   - **Indexer username** / **Indexer password** — optional; defaults to manager credentials
   - **Skip TLS verify** — enable only for lab environments with self-signed certificates
4. Click **Save & test**. A successful connection confirms both the manager API and indexer are reachable.
### 3. Explore your data
Open **Explore**, select the Wazuh datasource, choose a data type (alerts, vulnerabilities, FIM, SCA, or agent status), and run a query.
## Bundled dashboards
The plugin includes ready-made dashboards:
- Security Overview
- Vulnerabilities
- FIM
- SCA
- Agent Status
Find them under the **Wazuh** folder after installation. If you provision dashboards via YAML, set the datasource **`uid: wazuh`**.
## Further reading
- [Installation and configuration](https://github.com/armanfeyzi/grafana-wazuh-data-source/blob/main/docs/installation.md)
- [RBAC permissions](https://github.com/armanfeyzi/grafana-wazuh-data-source/blob/main/docs/rbac.md)
- [Kubernetes deployment](https://github.com/armanfeyzi/grafana-wazuh-data-source/blob/main/docs/kubernetes.md)
- [Source repository](https://github.com/armanfeyzi/grafana-wazuh-data-source)
## License
Apache 2.0
