title: "FlowX panel plugin for Grafana"
description: "Flow charting visualization. FlowX panel plugin for Grafana by anilhut. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/anilhut-flowx-panel/
# FlowX
- Developer: anilhut
- Version: 2.3.1
- [Change log](https://grafana.com/grafana/plugins/anilhut-flowx-panel/changelog.md)
![Screenshot 01](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/Screenshot_02_01.png)
![Screenshot 02](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/Screenshot_02_02.png)
![Screenshot 03](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/Screenshot_02_03.png)
![Screenshot 04](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/Screenshot_02_04.png)
![FlowX Overview](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/flowx-overview.gif)
![Layout Direction](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/flowx-layout-direction.gif)
![Collapse and Expand](https://grafana.com/api/plugins/anilhut-flowx-panel/versions/2.3.1/images/img/flowx-collapse-expand.gif)
[![Grafana Downloads](https://img.shields.io/badge/dynamic/json?url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins%2Fanilhut-flowx-panel\&query=%24.downloads\&label=downloads\&color=F47A20\&logo=grafana\&logoColor=white)](https://grafana.com/grafana/plugins/anilhut-flowx-panel/) [![Grafana Plugin Version](https://img.shields.io/badge/dynamic/json?url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins%2Fanilhut-flowx-panel\&query=%24.version\&label=version\&color=F47A20\&logo=grafana\&logoColor=white)](https://grafana.com/grafana/plugins/anilhut-flowx-panel/) [![GitHub Stars](https://img.shields.io/github/stars/anilhut/flowx?style=flat\&logo=github)](https://github.com/anilhut/flowx) [![GitHub Issues](https://img.shields.io/github/issues/anilhut/flowx?style=flat\&logo=github)](https://github.com/anilhut/flowx/issues) [![Support on Gumroad](https://img.shields.io/badge/Support%20on-Gumroad-pink?style=flat)](https://anilhut.gumroad.com/l/support-flowx-development) [![LinkedIn](https://img.shields.io/badge/LinkedIn-anilhut-blue?style=flat\&logo=linkedin)](https://www.linkedin.com/in/anilhut)
The FlowX Grafana panel enables the rendering of interactive flowcharts derived from directed graph data, consisting of nodes and edges. FlowX supports a variety of node types, each designed for specific use cases. Grafana provides a Node Graph panel for visualizing directed graph data, but its visualization capabilities are quite limited. To address the need for more advanced and rich visualizations of directed graphs, this panel has been developed. It leverages ReactFlow and DagreJS to deliver enhanced visualization features.
## Demo
![FlowX Overview](https://raw.githubusercontent.com/anilhut/flowx/main/src/img/flowx-overview.gif)
![Layout Direction](https://raw.githubusercontent.com/anilhut/flowx/main/src/img/flowx-layout-direction.gif)
![Collapse & Expand](https://raw.githubusercontent.com/anilhut/flowx/main/src/img/flowx-collapse-expand.gif)
## Requirements
| FlowX Version   | Minimum Grafana Version |
| 2.0.0+          | 11.6.11                 |
| 1.0.3 and below | 10.1.0                  |
> **Note:** FlowX 2.0.0+ requires Grafana 11.6.11 or higher due to React 19 compatibility changes introduced in Grafana 13. If you are running Grafana 10.x, please use FlowX version 1.0.3.
## Installation
Installing plugin on Grafana Cloud / Local Grafana - <https://grafana.com/docs/grafana/latest/plugins/installation/>
## Configuration
To use the FlowX panel, 2 different queries called "Node" and "Edge" must be added. The "Node" query is for determining the boxes, circles and diamonds we will draw. The "Edge" query is for determining the relationship between the nodes we draw. The expected columns in Node and Edge queries are as shared below. All data to come to the columns are optional (yes, including IDs, if an empty row comes, an empty node with no relationship will be drawn.) **The expected data type is string for all columns.**
## Node
The following table describes expected columns of the Node query:
| Columns         | Supported Values        | Description        |
| id              |        | Unique identifier of the Node. Each Node to be drawn must have a unique ID. These ID's will be used in the Source or Target fields in the "Edge" query.                          |
| type            | `title` `one` `two` `three` `four` `five` `six` `circle` `diamond`                                                              | Determines the type of Node. The Node is drawn according to this data. However, if the popup is active, all values will appear there. Default: `four`                            |
| title           |        | Title of the Node.        |
| value1_header   |        | The header that will come for the first value of the node.        |
| value1_data     |        | The data that will come for the first value of the node.        |
| value1_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value2_header   |        | The header that will come for the second value of the node.        |
| value2_data     |        | The data that will come for the second value of the node.        |
| value2_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value3_header   |        | The header that will come for the third value of the node.        |
| value3_data     |        | The data that will come for the third value of the node.        |
| value3_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value4_header   |        | The header that will come for the fourth value of the node.        |
| value4_data     |        | The data that will come for the fourth value of the node.        |
| value4_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value5_header   |        | The header that will come for the fifth value of the node.        |
| value5_data     |        | The data that will come for the fifth value of the node.        |
| value5_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value6_header   |        | The header that will come for the sixth value of the node.        |
| value6_data     |        | The data that will come for the sixth value of the node.        |
| value6_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value7_header   |        | The header that will come for the seventh value of the node.        |
| value7_data     |        | The data that will come for the seventh value of the node.        |
| value7_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value8_header   |        | The header that will come for the eighth value of the node.        |
| value8_data     |        | The data that will come for the eighth value of the node.        |
| value8_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value9_header   |        | The header that will come for the ninth value of the node.        |
| value9_data     |        | The data that will come for the ninth value of the node.        |
| value9_url      |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| value10_header  |        | The header that will come for the tenth value of the node.        |
| value10_data    |        | The data that will come for the tenth value of the node.        |
| value10_url     |        | One or more URLs. A plain address, or JSON for several labelled links — see [Multiple Links](#multiple-links). "Show Popup" must be on to use.                                   |
| color_condition | `red` `red_blink` `orange` `orange_blink` `yellow` `yellow_blink` `green` `green_blink` `blue` `blue_blink` `gray` `gray_blink` | Field that determines the background color of the node. Blink ones flash. Default: _null_        |
| url             |        | Field that can be used for the node's own URL. Accepts the same single-or-JSON format as the value URLs — see [Multiple Links](#multiple-links). "Show Popup" must be on to use. |
| url_label       |        | Names the node's own URL button. With JSON holding several links it names both the button and the list it opens; left empty there, the button reads "Links".                     |
## Multiple Links
Every URL column — `value1_url` through `value10_url` and the node's own `url` — accepts either a single address or JSON describing any number of labelled links:
```json
  { "label": "Runbook", "url": "https://wiki.example.com/runbook/auth" },
  { "label": "Dashboard", "url": "https://grafana.example.com/d/abc" },
  { "label": "Source", "url": "https://github.com/example/auth-api" }
These shapes are all accepted:
| Cell content                                     | Result        |
| `https://example.com`                            | One link, labelled with the address itself. This is the original format and keeps working unchanged. |
| `[{"label":"Runbook","url":"https://..."}, ...]` | Any number of labelled links.        |
| `{"label":"Runbook","url":"https://..."}`        | A single labelled link.        |
| `["https://a","https://b"]`                      | Two links, each labelled with its address.                                                           |
Notes:
- The links live in the node popup, so **Show Popup** must be on for any of this to be reachable.
- An entry with no usable `url` is dropped, and a missing `label` falls back to the address.
- **One link** opens directly when the icon is clicked, exactly as before. **Several links** show a count on the icon and open a list at the icon itself, in front of the node popup; close it with its ✕, `Esc`, or by clicking anywhere outside it — including the node popup itself, which stays open. Clicking the same icon again closes it. The list stays within the panel, moving itself inward when opened near an edge.
- For the node's own URL, `url_label` still names the button when set. With several links it names both the button and the list.
- Only `http` and `https` addresses, plus Grafana-internal paths beginning with `/`, are rendered. Anything else is ignored.
- A cell that starts like JSON but does not parse produces no links rather than a broken one, so a typo in a single row cannot break the popup.
Most data sources can build the JSON in the query itself, so no transformation is needed. In SQL:
```sql
SELECT
  service                                   AS id,
  'two'                                     AS type,
  service                                   AS title,
  'latency'                                 AS value1_header,
  latency_ms || ' ms'                       AS value1_data,
  json_build_array(
    json_build_object('label', 'Runbook',   'url', runbook_url),
    json_build_object('label', 'Dashboard', 'url', dashboard_url)
  )::text                                   AS value1_url
FROM services;
## Edge
The following table describes expected columns of the Edge query:
| Columns | Description        |
| id      | Unique identifier of the Edge. Each Edge to be drawn must have a unique ID. |
| source  | Source Node ID                                                              |
| target  | Target Node ID                                                              |
#### Supported Types of Node
| type    | Description        |
| _null_  | Default, node type will be set as `four`.                                             |
| title   | Node showing only `title` column.                                                     |
| one     | Node showing `title`, `value1_header`, `value1_data`.                                 |
| two     | Node showing `title`, `value1_header`, `value1_data`, `value2_header`, `value2_data`. |
| three   | Node showing `title` and value rows 1–3.                                              |
| four    | Node showing `title` and value rows 1–4.                                              |
| five    | Node showing `title` and value rows 1–5.                                              |
| six     | Node showing `title` and value rows 1–6.                                              |
| seven   | Node showing `title` and value rows 1–7.                                              |
| eight   | Node showing `title` and value rows 1–8.                                              |
| nine    | Node showing `title` and value rows 1–9.                                              |
| ten     | Node showing `title` and value rows 1–10.                                             |
| circle  | A node with circle shape that does not display value columns on the node itself.      |
| diamond | A node with diamond shape that does not display value columns on the node itself.     |
> If "Show Popup" is enabled, all fields (title, values 1–10, URL) are shown in the popup regardless of node type.
#### Supported Colors of Node
| color_condition | Description                           |
| _null_          | Default, paints the background white. |
| red             | Paints the background #f2495c.        |
| red_blink       | Blinks between #f2495c and white.     |
| orange          | Paints the background #ff9830.        |
| orange_blink    | Blinks between #ff9830 and white.     |
| yellow          | Paints the background #fade2a.        |
| yellow_blink    | Blinks between #fade2a and white.     |
| green           | Paints the background #73bf69.        |
| green_blink     | Blinks between #73bf69 and white.     |
| blue            | Paints the background #5794f2.        |
| blue_blink      | Blinks between #5794f2 and white.     |
| gray            | Paints the background #ebebeb.        |
| gray_blink      | Blinks between #ebebeb and white.     |
## Collapse / Expand
Every node that has children displays a small collapse/expand button at the point where its outgoing edge begins. Clicking it hides or reveals the subtree beneath that node.
- Collapsing a node hides all of its descendants and collapses them automatically.
- Expanding a node shows only its direct children. Grandchildren remain collapsed until manually expanded.
- Nodes with multiple parents remain visible as long as at least one parent is open.
- Cycles in the graph (A → B → A) are handled safely.
- The layout is animated: nodes that stay slide to their new position, nodes that appear grow out of their nearest visible ancestor, and nodes that disappear shrink back into it. The animation is skipped when the operating system requests reduced motion.
- Collapsing a subtree frees the space it occupied, so the remaining nodes close ranks. The rest of the graph is held in place, so only the branch you toggled moves.
The **Initial Depth** panel option controls how many levels are visible when the panel first loads:
| Value | Behavior                                      |
| `0`   | All nodes expanded (default)                  |
| `1`   | Only root nodes visible                       |
| `2`   | Roots and their direct children visible       |
| `n`   | Nodes up to depth `n` visible, rest collapsed |
The **Reset to Default** button (top-left corner, visible when "Show Layout Options" is on) clears all manually dragged positions and resets the collapse state back to the configured Initial Depth.
Below it, the **Expand All** button opens every node. Once the graph is fully open it turns into **Collapse All**, which folds the graph back to its root nodes. Both frame the whole graph and keep manually dragged positions.
## FlowX Panel Options
The following table describes FlowX panel options:
| Category            | Option                      | Values                                                  | Default           | Description        |
| Background Settings | Background Color            | Grafana Color Palette                                   | `#ffffff`         |        |
| Background Settings | Background Type             | `None` `Dots` `Cross` `Lines`                           | `None`            |        |
| Background Settings | Type Gap                    | 1 – 50                                                  | `28`              |        |
| Background Settings | Type Size                   | 1 – 10                                                  | `1`               |        |
| Background Settings | Type Color                  | Grafana Color Palette                                   | `#000000`         |        |
| Layout Settings     | Layout Direction            | `Top to Bottom` `Left to Right`                         | `Top to Bottom`   |        |
| Layout Settings     | Show Layout Options         | `on` `off`                                              | `on`              |        |
| Layout Settings     | Show Mini Map               | `on` `off`                                              | `on`              |        |
| Layout Settings     | Show Controls               | `on` `off`                                              | `on`              |        |
| Layout Settings     | Hide Attribution (Pro)      | `on` `off`                                              | `off`             | Please only hide the attribution if you are subscribed to React Flow Pro: <https://reactflow.dev/pro>                                      |
| Layout Settings     | Maximum Zoom                | 1 – 10                                                  | `4`               |        |
| Layout Settings     | Minimum Zoom                | 0.1 – 1                                                 | `0.1`             |        |
| Node Settings       | Draggable Nodes             | `on` `off`                                              | `off`             | Drag positions are preserved across data refreshes. Reset to Default clears them.                                                          |
| Node Settings       | Fit View on Collapse/Expand | `on` `off`                                              | `off`             | Moves the view to the toggled node: expanding frames it with its new children, collapsing with its siblings.                               |
| Node Settings       | Show Popup                  | `on` `off`                                              | `off`             | Must be enabled to use Node or Value URLs.        |
| Node Settings       | Initial Depth               | integer ≥ 0                                             | `0`               | Number of levels visible on load. `0` = all expanded. See Collapse / Expand section above.                                                 |
| Node Style          | Node Background Color       | Grafana Color Palette                                   | `#ffffff`         | Nodes with a `color_condition` use that color instead; `*_blink` alternates with this one. The node popup takes all Node Style colors too. |
| Node Style          | Title Background Color      | Grafana Color Palette                                   | `#ebebeb`         | The title strip of value nodes, and title nodes.        |
| Node Style          | Border Color                | Grafana Color Palette                                   | `#000000`         |        |
| Node Style          | Title Color                 | Grafana Color Palette                                   | `#000000`         |        |
| Node Style          | Title Font Size             | 10 – 16                                                 | `14`              |        |
| Node Style          | Value Header Color          | Grafana Color Palette                                   | `#000000`         |        |
| Node Style          | Value Header Font Size      | 10 – 16                                                 | `14`              |        |
| Node Style          | Value Color                 | Grafana Color Palette                                   | `#000000`         |        |
| Node Style          | Value Font Size             | 10 – 16                                                 | `14`              | Font sizes apply to nodes only, not the popup, and are capped at 16 so the text fits the fixed node size.                                  |
| Edge Settings       | Edge Animation              | `on` `off`                                              | `on`              |        |
| Edge Settings       | Edge Type                   | `Default` `Straight` `Step` `Smoothstep` `Simplebezier` | `Default`         |        |
| Edge Settings       | Edge Stroke                 | 1 – 10                                                  | `1`               |        |
| Edge Settings       | Edge Color                  | Grafana Color Palette                                   | `#000000`         |        |
| Node Field Mapping  | ID                          | string                                                  | `id`              | Maps a custom column name to the `id` field. Leave empty to use default.        |
| Node Field Mapping  | Type                        | string                                                  | `type`            | Maps a custom column name to the `type` field. Leave empty to use default.        |
| Node Field Mapping  | Title                       | string                                                  | `title`           | Maps a custom column name to the `title` field. Leave empty to use default.        |
| Node Field Mapping  | Color Condition             | string                                                  | `color_condition` | Maps a custom column name to the `color_condition` field. Leave empty to use default.                                                      |
| Node Field Mapping  | URL                         | string                                                  | `url`             | Maps a custom column name to the `url` field. Leave empty to use default.        |
| Node Field Mapping  | URL Label                   | string                                                  | `url_label`       | Maps a custom column name to the `url_label` field. Leave empty to use default.                                                            |
| Node Field Mapping  | Value 1 Header              | string                                                  | `value1_header`   | Maps a custom column name to the `value1_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 1 Data                | string                                                  | `value1_data`     | Maps a custom column name to the `value1_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 1 URL                 | string                                                  | `value1_url`      | Maps a custom column name to the `value1_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 2 Header              | string                                                  | `value2_header`   | Maps a custom column name to the `value2_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 2 Data                | string                                                  | `value2_data`     | Maps a custom column name to the `value2_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 2 URL                 | string                                                  | `value2_url`      | Maps a custom column name to the `value2_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 3 Header              | string                                                  | `value3_header`   | Maps a custom column name to the `value3_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 3 Data                | string                                                  | `value3_data`     | Maps a custom column name to the `value3_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 3 URL                 | string                                                  | `value3_url`      | Maps a custom column name to the `value3_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 4 Header              | string                                                  | `value4_header`   | Maps a custom column name to the `value4_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 4 Data                | string                                                  | `value4_data`     | Maps a custom column name to the `value4_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 4 URL                 | string                                                  | `value4_url`      | Maps a custom column name to the `value4_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 5 Header              | string                                                  | `value5_header`   | Maps a custom column name to the `value5_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 5 Data                | string                                                  | `value5_data`     | Maps a custom column name to the `value5_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 5 URL                 | string                                                  | `value5_url`      | Maps a custom column name to the `value5_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 6 Header              | string                                                  | `value6_header`   | Maps a custom column name to the `value6_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 6 Data                | string                                                  | `value6_data`     | Maps a custom column name to the `value6_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 6 URL                 | string                                                  | `value6_url`      | Maps a custom column name to the `value6_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 7 Header              | string                                                  | `value7_header`   | Maps a custom column name to the `value7_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 7 Data                | string                                                  | `value7_data`     | Maps a custom column name to the `value7_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 7 URL                 | string                                                  | `value7_url`      | Maps a custom column name to the `value7_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 8 Header              | string                                                  | `value8_header`   | Maps a custom column name to the `value8_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 8 Data                | string                                                  | `value8_data`     | Maps a custom column name to the `value8_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 8 URL                 | string                                                  | `value8_url`      | Maps a custom column name to the `value8_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 9 Header              | string                                                  | `value9_header`   | Maps a custom column name to the `value9_header` field. Leave empty to use default.                                                        |
| Node Field Mapping  | Value 9 Data                | string                                                  | `value9_data`     | Maps a custom column name to the `value9_data` field. Leave empty to use default.                                                          |
| Node Field Mapping  | Value 9 URL                 | string                                                  | `value9_url`      | Maps a custom column name to the `value9_url` field. Leave empty to use default.                                                           |
| Node Field Mapping  | Value 10 Header             | string                                                  | `value10_header`  | Maps a custom column name to the `value10_header` field. Leave empty to use default.                                                       |
| Node Field Mapping  | Value 10 Data               | string                                                  | `value10_data`    | Maps a custom column name to the `value10_data` field. Leave empty to use default.                                                         |
| Node Field Mapping  | Value 10 URL                | string                                                  | `value10_url`     | Maps a custom column name to the `value10_url` field. Leave empty to use default.                                                          |
| Edge Field Mapping  | ID                          | string                                                  | `id`              | Maps a custom column name to the edge `id` field. Leave empty to use default.                                                              |
| Edge Field Mapping  | Source                      | string                                                  | `source`          | Maps a custom column name to the `source` field. Leave empty to use default.                                                               |
| Edge Field Mapping  | Target                      | string                                                  | `target`          | Maps a custom column name to the `target` field. Leave empty to use default.                                                               |
## Field Mapping
If your data source uses different column names than the FlowX defaults (e.g. Elasticsearch, custom SQL), you can remap them using the **Node Field Mapping** and **Edge Field Mapping** panel option categories.
**Example:** Your Elasticsearch index has a field called `status` instead of `color_condition`. Set _Color Condition_ to `status` in Node Field Mapping and FlowX will read from that column automatically.
- All mapping fields are **optional**. Leave them empty to use the default column names.
- Only the fields you configure are overridden — the rest continue to use defaults.
- Grafana's built-in field rename transformations still work alongside this feature.
## Support
Support the continued development of FlowX for Grafana. Your contribution helps fund new features, improvements, bug fixes, and long-term maintenance. ☕
[![Support on Gumroad](https://img.shields.io/badge/Support%20on-Gumroad-pink?style=for-the-badge)](https://anilhut.gumroad.com/l/support-flowx-development)
## Contact
[![LinkedIn](https://img.shields.io/badge/LinkedIn-anilhut-blue?style=for-the-badge\&logo=linkedin)](https://www.linkedin.com/in/anilhut)
## Credits and References
1. [ReactFlow](https://reactflow.dev/)
2. [DagreJS](https://github.com/dagrejs/dagre)
3. [Build a panel plugin tutorial](https://grafana.com/tutorials/build-a-panel-plugin)
4. [Grafana documentation](https://grafana.com/docs/)
5. [Grafana Tutorials](https://grafana.com/tutorials/)
6. [Grafana UI Library](https://developers.grafana.com/ui)
