Plugins 〉Vega
Developer
Jarrad Whitaker <akdor1154>
  • Grafana, of course
  • 50 GB logs
  • 50 GB traces
  • 2,232 app o11y host hours
  • ...and more
Create free account
No credit card needed, ever.
Panel
community
Vega
  • Overview
  • Installation
  • Change log
  • Related content
Grafana-Vega
This is a panel plugin for Grafana that allows you to configure Vega or Vega-Lite specs.
A screenshot of the grafana-vega plugin in action
Features
  • The ability to write Vega/Vega Lite specs, which are much more powerful than the inbuilt Grafana vizes. (Gallery). <3 Vega.
  • A JSON editor with the Vega specs hooked up to it for autocomplete Autocomplete in action
  • Field names and Datasource names also hooked up to autocomplete Autocompleting fields in action
  • Automatic light/dark mode as per your Grafana theme Light mode
  • An obsessive amount of mucking about with React to stop your spec being reparsed all the time
  • {"width": "container"} hooked up to work like you want
Todo
  • Rig up Edit in Vega Editor and the other things you expect from Vega Embed
  • Dig into if it's possible to cope when Grafana sends us multiple dataframes with the same name/refId
  • Get it signed
Acknowledgements
Installing Vega on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install Vega from the commandline:
grafana-cli plugins install
Changelog
1.0.11
  • Switch bundler to Vite for AMD support
1.0.10
  • Fix rich text in schema autocomplete
1.0.9
  • Fix endless rerender loop when editing
1.0.8
  • Ensure provisioning works
1.0.7
  • Make dark theme better
1.0.6
  • Wire up Vega support (previously just Vega-Lite worked)
1.0.4
  • Initial release.
