Pydio Cells Monitoring
Dashboard for monitoring Cells metrics exposed via Prometheus.
This is a dashboard for Pydio Cells metrics. It exposes useful information about the processes’ status: memory, go-routines, average response times for REST and GRPC calls, etc.
Prerequisites to collect the metrics are the following:
  • Enable the metrics endpoints on Cells by exporting the environment variable CELLS_ENABLE_METRICS=true or by adding the flag --enable_metrics to cells’ start command.
  • Prometheus
and for the prometheus.yml configuration append this instruction.
yaml
- job_name: "cells"
    file_sd_configs:
      - files:
          - ${CELLS_WORKING_DIR}/services/pydio.gateway.metrics/prom_clients.json
Make sure to replace $CELLS_WORKING_DIR by your actual working directory.
