RealUptime Monitor
Uptime, latency, failing checks, open incidents and per-region status for every monitor in a RealUptime account, from RealUptime's Prometheus/OpenMetrics endpoint (GET /api/v1/metrics).
RealUptime Monitor screenshot 1
Live state of every RealUptime monitor, region by region: checks down right now, open incidents, the worst run of consecutive failures, time since each check last ran, latency over time and the latest HTTP status codes.
RealUptime is status pages, multi-region uptime monitoring, error tracking and free "Is X down?" pages on one flat-rate bill. Checks run from ten regions. The free plan covers four regions and 10 monitors, includes API keys, and needs no card.
Setup
  1. Create a RealUptime API key with the read scope at https://dashboard.realuptime.io/account/api-keys
  2. Add this scrape job to Prometheus, Grafana Alloy or Grafana Cloud Metrics:
scrape_configs:
  - job_name: realuptime
    scheme: https
    metrics_path: /api/v1/metrics
    scrape_interval: 60s
    authorization:
      type: Bearer
      credentials: YOUR_REALUPTIME_API_KEY
    static_configs:
      - targets: ["api.realuptime.io"]
  1. Import this dashboard and pick that Prometheus data source.
Metrics used
realuptime_check_up (1 up, 0 down), realuptime_check_latency_milliseconds, realuptime_check_consecutive_failures, realuptime_check_last_checked_timestamp_seconds, realuptime_check_status_code and realuptime_incident_open, each labelled by check and region.
The endpoint reports the latest reading of each check. The two "over time" panels plot the history Prometheus keeps across scrapes.
API reference: https://docs.realuptime.io/api Support: https://realuptime.io/support
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
