SLO burn rate and error budget (Prometheus, multi-window)
SLI, error budget and multi-window burn rates for the SLOs generated by the slo-burn-rate-alerts Helm chart.
SLO burn rate and error budget (Prometheus, multi-window) screenshot 1
SLO burn rate and error budget (Prometheus, multi-window) screenshot 2
SLO burn rate and error budget (Prometheus, multi-window) screenshot 3
One dashboard for every SLO in your Prometheus: the SLI over the SLO period, error budget remaining and spent, burn rate over 5m to 3d windows, how long the budget lasts at the current burn rate, firing burn-rate alerts and their history, and a table of all SLOs sorted by remaining budget.
Data it needs. The recording rules written by the slo-burn-rate-alerts Helm chart: slo:sli_error:ratio_rate5m to slo:sli_error:ratio_rate3d, slo:objective:ratio, slo:error_budget_remaining:ratio and friends, labelled slo and service. The chart writes them from SLOs given as Helm values or as OpenSLO v1 documents, on Prometheus Operator or Google Managed Prometheus. No operator or controller runs in the cluster.
How it differs from the Sloth dashboards. Same Google SRE Workbook maths (multi-window, multi-burn-rate page and ticket alerts), different source: Sloth's dashboards read Sloth's slo:* rules generated by its CLI or controller; this one reads the rules a plain Helm chart renders, and adds budget-lasts and alert-history panels.
Variables. Data source, SLO, and the SLO period (must match the chart's sloPeriodDays, 30d by default).
Getting started
helm repo add oreonit https://oreondev.github.io/helm-charts
helm install slo oreonit/slo-burn-rate-alerts -n monitoring -f my-slos.yaml
# or from OpenSLO documents:
helm install slo oreonit/slo-burn-rate-alerts -n monitoring --set-file openslo=slos.yaml
Values and examples: https://github.com/oreondev/helm-charts/tree/main/charts/slo-burn-rate-alerts
Maintained by Oreon IT. Issues and pull requests: https://github.com/oreondev/helm-charts
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
