Triadic System Dashboard — BI · BL · BS · BV
Canonical triadic dashboard: BI Overlay Health · BL Mode-Layer Operator · BS Coherence Pulse Oscilloscope · BV Multi-Trace Pulse+Severity
ResonanceInspector
Unified resonance inspection module using the full SARG → Benchmarks → HSP → RTT/12 lens stack.
AI‑Ready Summary
ResonanceInspector provides a consolidated, lens‑interpreted resonance view for downstream modules. It consumes RFR events, applies the full lens stack, and exposes a triadic‑ready interpretation surface for Opacity → Mode → TEL.
Session Context
  • Canon: TriadicFrameworks
  • Module: ResonanceInspector
  • Drift: 0 (canonical)
  • Coherence: structural, operator‑first
  • Version: 1.0
  • Format: Markdown + AI metadata
  • Front Door: index.html
  • Every Page: must preserve operator grammar
  • Audience: operators, diagnostics, AI‑agents
Module Identity
ResonanceInspector is the canonical analysis module that unifies:
  • RFR (Resonance Flight Recorder)
  • Lens Stack (SARG → Benchmarks → HSP → RTT/12)
  • Triadic Engine (Opacity → Mode → TEL)
It provides a stable, queryable resonance‑interpretation layer for all downstream modules.
Purpose
  • Interpret raw resonance traces using the full lens stack
  • Emit a structured, triadic‑ready resonance view
  • Provide diagnostics for drift, regime, sensitivity, and phase
  • Serve as a central inspection surface for operators and AI agents
Scope
ResonanceInspector covers:
  • RFR event ingestion
  • Lens‑stack propagation
  • Phase‑aligned interpretation
  • Engine‑ready output formatting
  • Structural diagnostics
It does not perform engine transformations itself (Opacity/Mode/TEL remain separate modules).
Operators
Primary:
  • inspect_resonance
  • emit_lens_view
  • validate_phase_alignment
Secondary:
  • compare_regimes
  • threshold_diff
  • phase_shift_detect
File Map
  • index.html — canonical front door
  • module.json — module identity + lens stack + integration
  • inspector_core.md — core operator logic
  • inspector_operators.md — operator grammar
  • inspector_diagnostics.md — drift + regime diagnostics
  • examples/ — single + batch examples
  • maps/ — SVG propagation maps
  • schema/ — unified schema + overlays
  • integration/ — propagation contracts
  • logs/ — overlays + validation logs
  • audit/ — phantom detection + drift checklist
  • schema/lens_rfr_engine.schema.json
  • integration/lens_stack_rfr_integration.json
  • maps/pipeline_map.svg
License
Open educational use permitted.
Contact
  • Author: Nawder Loswin
  • AI Contact: @TriadicFrameworks
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
