MinIO - System - Diagnostics
MinIO AIStor — System diagnostics. Top-5 timeseries paired with per-server distribution barcharts for CPU, memory, goroutines, drive throughput, and internode network. Use this dashboard when the operational system/* dashboards report cluster-wide pressure and you need to find which servers are responsible.
see documentation: https://docs.min.io/aistor/operations/monitoring/metrics-and-alerts/
MinIO
Easily monitor Minio, a Kubernetes-native high-performance object storage server, with Grafana Cloud's out-of-the-box monitoring solution.
