K3S cluster monitoring with node metrics
Monitors K3s cluster using Kube-Prometheus. Shows overall cluster CPU / Memory / Filesystem usage as well as individual pod, containers, systemd services statistics. Uses cAdvisor metrics + node metrics for top level stats. Origin from dashboard: 15282 (k8s-rke-cluster-monitoring), 8721(K8s RKE cluster monitoring) and will be compatible with k3s
Monitors K3s cluster using Kube-Prometheus. Shows overall cluster CPU / Memory / Filesystem usage as well as individual pod, containers, systemd services statistics. Uses cAdvisor metrics and node metrics.
Kubernetes
