Azure / Insights / Virtual Machines - OpenTelemetry - At Scale Default Metrics
Monitors Azure Virtual Machines using OpenTelemetry default metrics collected by VM Insights. Displays CPU utilization (overall, per-core, and by state), memory usage and utilization, disk I/O and operations, file system consumption, and network throughput, errors, and dropped packets. Scoped by subscription, resource group, and VM.
The Azure / Insights / Virtual Machines - OpenTelemetry - At Scale Default Metrics dashboard uses the grafana-azure-monitor-datasource and prometheus data sources to create a Grafana dashboard with the bargauge, table and text panels.
Azure Cosmos DB
