Home Energy
Linier Energy Monitoring
The Home Energy dashboard uses the influxdb data source to create a Grafana dashboard with the barchart, gauge, stat and timeseries panels.
RevisionDescriptionCreated
Home Assistant
Home Assistant
by Grafana Labs
Grafana Labs solution
Easily monitor Home Assistant, an open source software platform designed for home automation, with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
