Azure / Insights / Applications / OTel / RPC Delta
OpenTelemetry dashboard providing RPC call delta metrics.
Azure / Insights / Applications / OTel / RPC Delta screenshot 1
Azure Monitor Application Insights with OpenTelemetry Metrics (RPC)
This dashboard requires OpenTelemetry metrics to be ingested into an Application Insights resource with OTLP enabled. For onboarding instructions, see App Insights with OTel
Note: This dashboard should only be used for metrics which are ingested in delta temporality and exponential histograms, the default setting for the Application Insights OpenTelemetry distro. Learn More
RevisionDescriptionCreated
Azure Cosmos DB
Azure Cosmos DB
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
