Linkerd HAZL: Multi-Zone Traffic & Cost Analysis
Comprehensive visibility into Linkerd's High Availability Zone-aware Load balancing (HAZL) across multi-zone Kubernetes clusters. Tracks same-zone locality scores, cross-AZ traffic volume and projected cost savings, zone-to-zone traffic flow, endpoint pool health, inbound/outbound latency by zone, and HAZL tuning guidance. Use to validate HAZL effectiveness, identify zone imbalances, and quantify egress cost reduction.
A Grafana dashboard for monitoring Linkerd's HAZL (High Availability Zone-aware Load balancing) in multi-zone Kubernetes clusters. It surfaces locality effectiveness, cross-AZ traffic costs, zone health, and endpoint pool state in one place.
Requirements
- Linkerd Enterprise (HAZL feature)
- Prometheus scraping Linkerd proxy metrics
- Node metrics with
topology.kubernetes.io/zonelabels (standard on EKS, GKE, AKS)
Dashboard sections
Overview — HAZL locality score (same-zone %), projected annual cross-AZ cost, same-AZ vs cross-AZ traffic volume
Zone Traffic Analysis — Zone-to-zone traffic matrix, cross-zone spill %, latency and success rate by destination zone
Cost Savings Estimate — Actual cost with HAZL vs estimated baseline without it, annual savings, traffic reduction %
Zone Health & Tuning — Pod count per zone, imbalance ratio, structural spill from skew, per-zone RPS/latency/connections, tuning guide
HAZL Endpoint Deep Dive — Active local vs remote endpoints, locality % per service, pool size over time
Outbound Latency & Errors — RPS, p50/p95/p99 latency, and error rate broken down by source zone
Template variables
Datasource — Prometheus datasource to use
Client Namespace — Filter by one or more namespaces (multi-select, defaults to all)
Client Deployment — Filter by deployment within the selected namespace(s)
Cross-AZ Traffic Cost ($/GB) — Cloud provider egress rate for cost projections (AWS/GCP $0.01, AWS bidirectional $0.02, Azure $0.00, or custom)
