WAZUH - SYSTEM VULNERABILITIES
Please Note. I used an extractor to format my log. To fix wazuh logs, replace _ with . eg (Change agent_name to agent.name in Grafana).Other than just using Kibana, You can use Elasticsearch data source to visualize Wazuh - SYSTEM VULNERABILITIES, on all Agents. I prefer Grafana because it loads faster and allows me to consolidate multiple data sources, such as Prometheus and InfluxDB, into a single source of truth.
The WAZUH - SYSTEM VULNERABILITIES dashboard uses the elasticsearch data source to create a Grafana dashboard with the bargauge, piechart, stat, table and table-old panels.
