Moen Flo Water (via Home Assistant)
display water flow values through Moen Flo water sensor
The Moen Flo Water (via Home Assistant) dashboard uses the prometheus data source to create a Grafana dashboard with the stat and timeseries panels.
RevisionDescriptionCreated
Home Assistant
Home Assistant
by Grafana Labs
Grafana Labs solution
Easily monitor Home Assistant, an open source software platform designed for home automation, with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
