Infrastructure Monitoring - USE Framework
Infrastructure monitoring template using the USE (Utilization, Saturation, Errors) methodology. Monitor Kubernetes clusters from nodes to pods with resource metrics, bottleneck detection, and stability tracking. Ready for instant integration with Prometheus or other datasources.
The Infrastructure Monitoring - USE Framework dashboard uses the grafana-testdata-datasource data source to create a Grafana dashboard with the stat, table, text and timeseries panels.
Splunk Infrastructure Monitoring
With the Grafana plugin for Splunk Infrastructure Monitoring, you can quickly visualize your metrics and analytics in Grafana.
