System and Containers Monitoring and Logs
Host, Docker container metrics and logs per host, collected by Grafana Alloy into Prometheus/Mimir + Loki. v2: per-host filtering, CPU by mode, PSI, filesystems, container table, log search.
System and Containers Monitoring and Logs screenshot 1
System and Containers Monitoring and Logs screenshot 2
Host, Docker container metrics and logs in one dashboard. Pick a host and you get its CPU, memory, pressure, network, disks and filesystems, every container's CPU, memory, I/O and network, and the container and systemd journal logs, with a text search.
Everything is collected by Grafana Alloy on each host. Metrics go to any Prometheus-compatible store (Grafana Mimir, Prometheus) and logs to Grafana Loki.
Requirements
  • Grafana 11 or later.
  • A Prometheus-compatible datasource and a Loki datasource. They are chosen with the dashboard's Metrics and Logs variables.
  • Grafana Alloy on every host, using the same labels everywhere. See below.
  • Optional: docker_container_exporter, for the count of containers that are not running. cAdvisor only sees running containers.
Labels the dashboard expects
SourceAlloy componentLabels
Host metrics node_*prometheus.exporter.unixinstance = host name
Container metrics container_*prometheus.exporter.cadvisorinstance = host name, name = container
Container counts docker_containers_*scrape of docker_container_exporterinstance = host name
Container logsloki.source.dockerapplication="docker", instance, container_name
Journalloki.source.journalapplication="journal", instance, unit
The Host variable lists label_values(node_uname_info, instance). Use the same instance value in every source of a host.
Minimal Alloy configuration (one host)
// --- metrics ---------------------------------------------------------------
prometheus.exporter.unix "host" { }
discovery.relabel "host" { targets = prometheus.exporter.unix.host.targets rule { target_label = "instance" replacement = constants.hostname } }
prometheus.scrape "host" { targets = discovery.relabel.host.output forward_to = [prometheus.remote_write.default.receiver] }
prometheus.exporter.cadvisor "containers" { docker_host = "unix:///var/run/docker.sock" storage_duration = "1m" }
prometheus.scrape "cadvisor" { targets = prometheus.exporter.cadvisor.containers.targets forward_to = [prometheus.relabel.cadvisor.receiver] }
// cAdvisor copies every docker label into container_label_: too many labels per series // (Mimir rejects more than 30 by default) and new series on every redeploy. Keep only // the compose project/service. prometheus.relabel "cadvisor" { forward_to = [prometheus.remote_write.default.receiver] rule { source_labels = ["container_label_com_docker_compose_project"] target_label = "compose_project" } rule { source_labels = ["container_label_com_docker_compose_service"] target_label = "compose_service" } rule { regex = "container_label_." action = "labeldrop" } rule { target_label = "instance" replacement = constants.hostname } }
// optional: github.com/oriolrius/docker_container_exporter on :8118 prometheus.scrape "container_counts" { targets = [{"address" = "127.0.0.1:8118", "instance" = constants.hostname}] forward_to = [prometheus.remote_write.default.receiver] }
prometheus.remote_write "default" { endpoint { url = "http://mimir:8080/api/v1/push" // or Prometheus /api/v1/write } }
// — logs —————————————————————— discovery.docker "containers" { host = "unix:///var/run/docker.sock" }
discovery.relabel "docker_logs" { targets = [] rule { source_labels = ["__meta_docker_container_name"] regex = "/(.*)" target_label = "container_name" } rule { target_label = "instance" replacement = constants.hostname } rule { target_label = "application" replacement = "docker" } }
loki.source.docker "containers" { host = "unix:///var/run/docker.sock" targets = discovery.docker.containers.targets relabel_rules = discovery.relabel.docker_logs.rules forward_to = [loki.write.default.receiver] }
loki.relabel "journal" { forward_to = [] rule { source_labels = ["__journal__systemd_unit"] target_label = "unit" } rule { target_label = "instance" replacement = constants.hostname } rule { target_label = "application" replacement = "journal" } }
loki.source.journal "host" { relabel_rules = loki.relabel.journal.rules forward_to = [loki.write.default.receiver] }
loki.write "default" { endpoint { url = "http://loki:3100/loki/api/v1/push" } }
Running Alloy in a container instead of as a service
The container needs access to the host. Configure it as follows.
Mount the host paths:
  • /proc:/host/proc:ro, /sys:/host/sys:ro and /:/host/root:ro,rslave. Then set procfs_path, sysfs_path and rootfs_path on prometheus.exporter.unix.
  • /var/run/docker.sock, /sys:/sys:ro, the Docker data root (e.g. /var/lib/docker) and /dev/disk (all read-only), for cAdvisor.
  • /var/log/journal and /etc/machine-id, for the journal.
Run it with pid: host. Without it, cAdvisor reports no per-container network traffic.
If the container is not on the host network, host network counters need a second exporter, because /proc/net/dev shows the reader's own network namespace:
prometheus.exporter.unix "host_net" {
  procfs_path    = "/host/proc/1"
  set_collectors = ["netdev"]
Hosts with many containers
cAdvisor uses inotify. If Alloy logs inotify_init: too many open files, raise fs.inotify.max_user_instances (e.g. to 1024 in /etc/sysctl.d/).
Revision 2 (2026-10)
  • Every panel is filtered by the selected host. Several revision 1 panels mixed all hosts.
  • Datasources are variables (Metrics, Logs). There are no hard-coded uids, and a single Loki is used: the application label tells container logs from journal logs.
  • Host CPU is broken down by mode. Revision 1 summed container system time.
  • Memory is broken down into used, cache and buffers, free, and swap.
  • New panels:
    • Linux pressure (PSI) for CPU, memory and IO;
    • a filesystems table with size, free space and free %;
    • a per-container table (CPU, RSS, swap);
    • text search for the logs;
    • a host reboot annotation.
  • Network and disk I/O are mirrored: in/read up, out/write down.
  • The Windows leftovers and the manual interval variable are gone; $__rate_interval is used instead.
RevisionDescriptionCreated
Grafana Loki (self-hosted)
by Grafana Labs
Grafana Labs solution
Easily monitor Grafana Loki (self-hosted), a horizontally scalable, highly available, multi-tenant log aggregation system inspired by Prometheus, with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
