K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana13, 2026, EN)
K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana13, 2026, EN) screenshot 1
K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana13, 2026, EN) screenshot 2
K8s Node Metrics / Multi Clusters (Node Exporter, Prometheus, Grafana13, 2026, EN) screenshot 3
About: K8s Node Metrics / Multi Clusters
  • A multi-cluster node monitoring dashboard.
  • Provides node-exporter metrics with multi-datasource (Prometheus) support.
  • English UI.
Variables
  • Datasource: select a Prometheus datasource registered in Grafana.
  • Cluster: filters by the cluster Prometheus metric label
    • Set via external_labels.cluster on each Prometheus.
    • Useful when one datasource aggregates multiple clusters (Thanos / unified Prometheus).
    • Ignored if you use a separate datasource per cluster.
  • Job, Interval: standard scope filters.
  • [Detail] Host / Instance / NIC: filters that affect only the Resource Details section.
Use case
  • We operate multiple Kubernetes clusters, with node-exporter and prometheus deployed to each cluster via the kube-prometheus-stack helm chart.
  • Goal: monitor metrics from multiple clusters in a centralized environment (1 dashboard, 1 Grafana).
Recommendation
  • Kiosk mode is recommended for better readability.
Source
Changelog
2026.06.
  • Support Grafana 13 (2026)
  • Support Dynamic Query: Datasource (Prometheus), Cluster, Job
    • Renamed origin_prometheuscluster (variable name, label, and metric label all unified)
  • Add Column Filter
2025
  • Support Grafana 11.3
  • Support Dynamic Selection for Multi-DataSource (Prometheus)
  • Default settings of table minWidth for vertical mode
  • Modify the design of some panels: Total CPU / Total Memory / Total Disk
  • Delete redirection links
    • Link URL redirection is unstable in the latest Grafana. Use label selection instead.
  • Note on 11074 base
    • 11074's style is very useful, and its publisher supports other advanced dashboards (e.g. 16098)
    • But they only support Chinese in the latest Grafana
RevisionDescriptionCreated
Kubernetes
Kubernetes
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
