Wireguard + WireRest (JVM)
Dashboard for monitoring Wireguard and WireRest API
This is a dashboard that will allow you to view:
- Number of peers
- How many peers are created in a period of time
- How many peers are removed per time interval
- How many free / total IP addresses (v4) in the interface that wireguard uses
- How much traffic wireguard clients spend
- WireRest API statistics
How to install:
Install WireRest on your server (the same one running Wireguard) GUIDE
Connect Prometheus to your WireRest
Example
- job_name: 'wirerest-demo'
scrape_interval: 5s
metrics_path: '/actuator/prometheus'
authorization:
credentials_file: '/PATH/TO/FILE/WITH/ACCESS_TOKEN'
static_configs:
- targets: ['WIREREST_URL:8081']
Do not forget create file with access token or disable it. The file must be accessible by the user prometheus
. Default token is “admin” About token
You can check the availability of WireRest as follows:
curl http://127.0.0.1:8081/actuator/prometheus?token=<YOUR_TOKEN>
- Install dashboard
Done!
if you find bugs or have a suggestion for improvement, please write about it in Github issue
Download |
