System Usage
Monitor Linux node : CPU, network traffic, memory status and system stats
Only requires the default job_name: node and target[addrs:portno] in prometheus.yml file. By default it take metrics form localhost:9100/metrics
- job_name: node
static_configs:
- targets: ['localhost:9100']
If the metrics are available at a specific path other than the default, it needs to be defined in the configuration file.
scrape_configs:
- job_name: "node"
static_configs:
- targets: ["localhost:9100"]
metrics_path: "/some/path"
Recommended for prometheus-node-exporter the arguments ‘–collector.systemd –collector.processes’ because the graph uses some of their metrics
