SUI Fullnode Monitor Dashboard
the monitor dashboard for SUI fullnode
SUI Fullnode Monitor Dashboard screenshot 1
SUI Fullnode Monitor Dashboard screenshot 2
Overview
This is a work-in-progress Grafana dashboard for monitoring SUI fullnode. Setting up Prometheus / Grafana is outside the scope of this cookbook.
Something you need to do in advance
  • Install node-exporter service. get it from github or just run apt install prometheus-node-exporter
  • Setup your prometheus.yml file like this:
- job_name: sui
    static_configs:
    # for sui node metrics
	- targets: ['localhost:9184']
	  labels:
	  chain: 'devnet' # or testnet
	# for machine metrics
	- targets: ['localhost:9100']
	  labels:
  • Install Infinity Plugin for Grafana. Install it by run grafana-cli plugins install yesoreyeram-infinity-datasource command on the grafana server, or from grafana.net cloud installs. after you finish install, go to your datasources and add a new datasource. choose type Infinity and hit save without any other configuration.
Then enjoy it :)
RevisionDescriptionCreated
Import the dashboard template
Datasource
Dependencies
