blackbox_exporter-http-Dashboards-english
blackbox_exporter HTTP monitoring panel
blackbox_exporter-http-Dashboards-english screenshot 1
blackbox_exporter-http-Dashboards-english screenshot 2
blackbox_exporter-http-Dashboards-english screenshot 3
Selector description
  • Project: the project tag corresponding to the target
  • App: app tag corresponding to target
v2 update summary
  • Examples with less than 30 days remaining for new certificates shall be listed separately
  • Add instance cell color matching of non HTTPS protocol
  • Fix the problem that fail displays no data when there are no failed hosts
  • Fix the problem that the proportion of failed instances and strength status is affected by the time range, and the data is inaccurate
  • Add the response code change record chart to view the response code changes in the past time
对应中文面板 : https://grafana.com/grafana/dashboards/16292
RevisionDescriptionCreated
Apache HTTP Server
Apache HTTP Server
by Grafana Labs
Grafana Labs solution
Easily monitor Apache HTTP Server, an open source HTTP server for modern operating systems including UNIX and Windows, with Grafana Cloud's out-of-the-box monitoring solution.
Import the dashboard template
Datasource
Dependencies
