Pydio Cells Monitoring (Advanced)
Dashboard for Pydio Cells, including additional data collected from third-party exporters
This is a dashboard for Pydio Cells metrics. It exposes useful information about the processes’ status: memory, go-routines, average response times for REST and GRPC calls, etc, as well as server-generic metrics collected from node_exporter, mysql_exporter, etc.
Prerequisites to collect the metrics are the following:
  • Enable the metrics endpoints on Cells by exporting the environment variable CELLS_ENABLE_METRICS=true or by adding the flag --enable_metrics to cells’ start command.
  • Prometheus
  • Node exporter
and for the prometheus.yml configuration append this instruction.
yaml
- job_name: "cells"
    file_sd_configs:
      - files:
          - ${CELLS_WORKING_DIR}/services/pydio.gateway.metrics/prom_clients.json
Make sure to replace $CELLS_WORKING_DIR by your actual working directory.
