IBM Workload Automation Grafana Dashboard for Distributed environments 9.5 FP4
Dashboard
Visualize Workload Automation metrics
Last updated: 9 months ago
Start with Grafana Cloud and the new FREE tier. Includes 10K series Prometheus or Graphite Metrics and 50gb Loki Logs
Reviews: 0
IBM Workload Automation Performance Dashboard
Overview
IBM Workload Automation uses Grafana to display performance data related to the product. This data includes metrics related to the server and console application servers (WebSphere Application Server Liberty Base), your workload, your workstations, critical jobs, message queues, the database connection status, and more. Metrics provide insight into the state, health, and performance of your deployments and infrastructure. IBM Workload Automation cloud metric monitoring uses an opensource Cloud Native Computing Foundation (CNCF) project called Prometheus. It is particularly useful for collecting time series data that can be easily queried.
Metrics
MetricDescription
WorkloadJobs by status, Jobs by workstation, Jobs by folder and the Workload throughput by jobs/minutes
Critical JobsIncomplete predecessors, critical jobs, risk level for potential and high risks, estimated end and confidential factor
WA Server Internal Message QueueInternal message queue usage for Appserverbox.msg, Courier.msg, mirrorbox.msg, Mailbox.msg, Monbox.msgn, Moncmd.msg, auditbox.msg, clbox.msg, planbox.msg, Intercom.msg, pobox messages, and server.msg
Workstation StatusThe number of running workstations and linked workstations
Database Connection StatusThe connection to the database status
WA Server and Console - LibertyHeap usage percentage, Active sessions, Live sessions, Active threads, Threadpool size and Time per garbage collection cycle moving average
WA Sever and Console - Connection Pools (Liberty)Average time usage per connection over last, Managed connections, Free connection, Connection handles and Created and Destroyed connections
For more information see our Documentation
Workload
Internal Message Queues
Workstation Status
Liberty
Note: Version 9.5, Fix Pack 4 is required to enable the following monitoring features:
  • Critical Jobs metric
  • Workstation status metric
  • Database connection status metric
  • Job, Job stream, and Workstation Filters
Earlier versions of the product enable only a subset of the monitoring features available with Version 9.5, Fix Pack 4.
This Dashboard is licensed under Apache 2.0 license.
Get this dashboard:
14693
