Cisco FTD System On Azure Application Insights
Basic Metrics from Cisco FTD devices uploaded to Azure Application Insights.
Cisco FTD System On Azure Application Insights screenshot 1
Cisco FTD System On Azure Application Insights screenshot 2
Cisco FTD System On Azure Application Insights screenshot 3
Cisco FTD System On Azure Application Insights screenshot 4
Cisco Firepower Threat Defence device can be configured to emit metrics to Azure Application Insights. This feature will be available to Cisco FTD customers in second half of calendar year 2021. The customers can monitor these metrics on this grafana dashboard by pointing the grafana dashboard to Azure Application Insight instance. To do that:
  1. Download and start Grafana
  2. On Grafana application, Go to Configure data source - Azure Monitor.
  3. Go to "Azure Application Insights Details" in the data source settings.
  4. Fill in the "API Key" and "Application Id" obtained from Azure Application Insights dashboard.
  5. In the dashboard, just fill in "deviceName" of the device you want to monitor and you will start receiving metrics for given device on the dashboard.
RevisionDescriptionCreated
Azure Cosmos DB
Azure Cosmos DB
by Grafana Labs
Grafana Labs solution
Import the dashboard template
Datasource
Dependencies
