Menu
Writers' Toolkit Writing guide Reuse directories of content
Reuse directories of content with Hugo mounts
Note: The following task can only be performed by a Grafana Labs employee.
Before Hugo performs a build, Hugo mounts mount a source directory at a destination directory. Use Hugo mounts to reuse a whole directory of content in another part of the published technical documentation.
Before you begin
  • Identify a directory of content that you want to reuse.
  • Identify any pages to exclude. Typically, excluded pages do not make sense in the context of the target directory.
    Warning: Pages in the directory might have relative links to other pages that would be broken by their exclusion. If the excluded page is replaced by another in the target directory, relative links will continue to work. Otherwise, the broken relative links should be made absolute. That way, they will always refer to the page in the source directory.
Steps
To reuse a shared directory:
  1. Determine the source and target directories.
    The source directory is the path to a directory in the website repository. It always has the path prefix content/docs/. The source directory for all Grafana Cloud content at the URL https://grafana.com/docs/grafana-cloud/ is content/docs/grafana-cloud.
    Similarly, the target directory has the path prefix content/docs. For the destination URL https://grafana.com/docs/target-directory/, the path is content/docs/target-directory.
  2. Update the website repository Hugo configuration.
    The configuration is in the in the website repository in the config/_default/config.yaml file.
    Append the mount to the docs.manual_mount key in the YAML configuration.
    For example, mount the source content/docs/source-directory at content/docs/target-directory and exclude the root _index.md file:
    - source: content/docs/source-directory
      target: content/docs/target-directory
      excludeFiles:
        - /_index.md
