title: "Set up monitoring for Tempo | Grafana Tempo documentation"
description: "Set up monitoring for Tempo"
# Set up monitoring for Tempo
You can set up monitoring for Tempo using an existing or new cluster. If you don’t have a cluster available, you can use the linked documentation to set up the Tempo, Mimir, and Grafana using Helm or you can use Grafana Cloud.
You can use this procedure to set up monitoring for Tempo running in monolithic (single binary) or microservices modes.
To set up monitoring, you need to:
- Use Grafana Alloy to remote-write to Tempo and set up Grafana to visualize the tracing data by following [Set up a test app](/docs/tempo/latest/setup/set-up-test-app/).
- Update your Alloy configuration to scrape metrics to monitor for your Tempo data.
This procedure assumes that you have set up Tempo [using the Helm chart](/docs/tempo/latest/setup/helm-chart/) with [Grafana Alloy](/docs/alloy/latest/set-up/install/).
The steps outlined below use the Alloy configurations described in [Set up a test application for a Tempo cluster](/docs/tempo/latest/setup/set-up-test-app/).
> Note
> Update any instructions in this document for your own deployment.
> If you use the [Kubernetes integration Grafana Alloy Helm chart](/docs/alloy/latest/set-up/install/kubernetes/), you can use the Kubernetes scrape annotations to automatically scrape Tempo. You’ll need to add the labels to all of the deployed components.
## Before you begin
To configure monitoring using the examples on this page, you’ll need the following running in your Kubernetes environment:
- Tempo instance - For storing traces and emitting metrics ( [install using the `tempo-distributed` Helm chart](/docs/tempo/latest/setup/helm-chart/))
- Mimir - For storing metrics emitted from Tempo ([install using the `mimir-distributed` Helm chart](/docs/helm-charts/mimir-distributed/latest/get-started-helm-charts/))
- Grafana - For visualizing traces and metrics ( [install on Kubernetes](/docs/grafana/next/setup-grafana/installation/kubernetes/#deploy-grafana-oss-on-kubernetes))
You can use Grafana Alloy or the OpenTelemetry Collector. This procedure provides examples only for Grafana Alloy.
The rest of this documentation assumes that the Tempo, Grafana, and Mimir instances use the same Kubernetes cluster.
If you are using Grafana Cloud, you can skip the installation sections and set up the [Mimir (Prometheus)](/docs/grafana-cloud/connect-externally-hosted/data-sources/prometheus/) and [Tempo data sources](/docs/grafana-cloud/connect-externally-hosted/data-sources/tempo/) in your Grafana instance.
## Use a test app for Tempo to send data to Grafana
Before you can monitor Tempo data, you need to configure Grafana Alloy to send traces to Tempo.
Use [these instructions to create a test application](/docs/tempo/latest/setup/set-up-test-app/) in your Tempo cluster. These steps configure Grafana Alloy to `remote-write` to Tempo. In addition, the test app instructions explain how to configure a Tempo data source in Grafana and view the tracing data.
> Note
> If you already have a Tempo environment, then there is no need to create a test app. This guide assumes that the Tempo and Grafana Alloy configurations are the same as or based on [these instructions to create a test application](/docs/tempo/latest/setup/set-up-test-app/), as you’ll augment those configurations to enable Tempo metrics monitoring.
In these examples, Tempo is installed in a namespace called `tempo`. Change this namespace name in the examples as needed to fit your own environment.
## Configure Grafana
In your Grafana instance, you’ll need:
- [A Tempo data source](/docs/grafana/next/datasources/tempo/configure-tempo-data-source/) (created in the previous section)
- A [Mimir (Prometheus) data source](/docs/grafana/next/datasources/prometheus/)
Metamonitoring for Tempo is handled by the [Grafana Kubernetes Helm chart](https://github.com/grafana/k8s-monitoring-helm) (&gt;=v2.1). Metamonitoring can be used with both microservices and single binary deployments of Tempo.
The Helm chart configures Grafana Alloy to collect metrics and logs.
## Steps
This procedure uses the [Grafana Kubernetes Helm chart](https://github.com/grafana/k8s-monitoring-helm) and a `values.yml` file to configure the chart.
1. Add the Grafana Community Helm Chart repository, or update, if already added.
   ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```none
   helm repo add grafana-community https://grafana-community.github.io/helm-charts
   helm repo update
2. Create a new file named `values.yml`. Add the following example into your `values.yml` file and save it. Where indicated, add the values specific to your instance.
   YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```yaml
   cluster:
       name: traces # Name of the cluster. This populates the cluster label.
   integrations:
       tempo:
           instances:
             - name: "traces" # This is the name for the instance label that reports.
               namespaces:
                   - traces # This is the namespace that is searched for Tempo instances. Change this accordingly.
               metrics:
                   enabled: true
                   portName: prom-metrics
               logs:
                   enabled: true
               labelSelectors:
                   app.kubernetes.io/name: tempo
   alloy:
   destinations:
   - name: "metrics"
     type: prometheus
     url: "<url>" # URL for Prometheus. Should look similar to "https://<prometheus host>/api/prom/push".
     auth:
       type: basic
       username: "<username>"
       password: "<password>"
   - name: "logs"
     type: loki
     url: "<url>" # URL for Loki. Should look similar to "https://<loki host>/loki/api/v1/push".
     auth:
       type: basic
   alloy-metrics:
       enabled: true
   podLogs:
       enabled: true
       gatherMethod: kubernetesApi
       namespaces: [traces] # Set to namespace from above under instances.
       collector: alloy-singleton
   alloy-singleton:
       enabled: true
   alloy-metrics:
       enabled: true # Sends Grafana Alloy metrics to ensure the monitoring is working properly.
3. Install the Helm chart using the following command to create Grafana Alloy instances to scrape metrics and logs:
   ```none
   helm install k8s-monitoring grafana/k8s-monitoring \
   --namespace monitoring \
   --create-namespace \
   -f values.yml
4. Verify that data is being sent to Grafana.
   - Log into Grafana.
   - Select Metrics Drilldown and select `cluster=<cluster.name>` where `cluster.name` is the name specified in the `values.yml` file.
   - Do the same for Logs Drilldown.
   This example doesn’t include ingestion for any other data such as traces for sending to Tempo, but can be included with some configuration updates. Refer to [Configure Alloy to remote-write to Tempo](/docs/tempo/latest/setup/set-up-test-app/) for more information.
## Install Tempo dashboards in Grafana
Alloy scrapes metrics from Tempo and sends them to Mimir or another Prometheus compatible time-series database. You can then monitor Tempo using the mixins.
Tempo ships with mixins that includes:
- Relevant dashboards for overseeing the health of Tempo as a whole, as well as its individual components
- Recording rules that simplify the generation of metrics for dashboards and free-form queries
- Alerts that trigger when Tempo falls out of operational parameters
To install the mixins in Grafana, you need to:
1. Download the mixin dashboards from the Tempo repository.
2. Import the dashboards in your Grafana instance.
3. Upload `alerts.yaml` and `rules.yaml` files for Mimir or Prometheus
### Download the `tempo-mixin` dashboards
1. First, clone the Tempo repository from Github:
   Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
   ```bash
   git clone git+ssh://github.com/grafana/tempo
2. Once you have a local copy of the repository, navigate to the `operations/tempo-mixin-compiled` directory.
   ```bash
   cd operations/tempo-mixin-compiled
This contains a compiled version of the alert and recording rules, as well as the dashboards.
> Note
> If you want to change any of the mixins, make your updates in the `operations/tempo-mixin` directory. Use the instructions in the [README](https://github.com/grafana/tempo/tree/main/operations/tempo-mixin) in that directory to regenerate the files. The mixins are generated in the `operations/tempo-mixin-compiled` directory.
### Import the dashboards to Grafana
The `dashboards` directory includes the eight monitoring dashboards that can be installed into your Grafana instance. Refer to [Import a dashboard](/docs/grafana/latest/dashboards/build-dashboards/import-dashboards/) in the Grafana documentation.
> Tip
> Install all eight dashboards. You can only import one dashboard at a time. Create a new folder in the Dashboards area, for example “Tempo Monitoring”, as an easy location to save the imported dashboards.
To create a folder:
1. Open your Grafana instance and select **Dashboards**.
2. Select **New** in the right corner.
3. Select **New folder** from the **New** drop-down.
4. Name your folder, for example, “Tempo Monitoring”.
5. Select **Create**.
To import a dashboard:
3. Select **Import**.
4. On the **Import dashboard** screen, select **Upload.**
5. Browse to `operations/tempo-mixin-compiled/dashboards` and select the dashboard to import.
6. Drag the dashboard file, for example, `tempo-operational.json`, onto the **Upload** area of the **Import dashboard** screen. Alternatively, you can browse to and select a file.
7. Select a folder in the **Folder** drop-down where you want to save the imported dashboard. For example, select Tempo Monitoring created in the earlier steps.
8. Select **Import**.
The imported files are listed in the Tempo Monitoring dashboard folder.
To view the dashboards in Grafana:
1. Select Dashboards in your Grafana instance.
2. Select Tempo Monitoring, or the folder where you uploaded the imported dashboards.
3. Select any files in the folder to view it.
The ‘Tempo Operational’ dashboard shows read (query) information:
### Add alerts and rules to Prometheus or Mimir
The rules and alerts need to be installed into your Mimir or Prometheus instance. To do this in Prometheus, refer to the [recording rules](https://prometheus.io/docs/prometheus/latest/configuration/recording_rules/) and [alerting rules](https://prometheus.io/docs/prometheus/latest/configuration/alerting_rules/) documentation.
For Mimir, you can use [mimirtool](/docs/mimir/latest/manage/tools/mimirtool/) to upload [rule](/docs/mimir/latest/manage/tools/mimirtool/#rules) and [alert](/docs/mimir/latest/manage/tools/mimirtool/#alertmanager) configuration. Using a default installation of Mimir used as the metrics store for the Alloy configuration, you might run the following:
```bash
mimirtool rules load operations/tempo-mixin-compiled/rules.yaml --address=https://mimir-cluster.distributor.mimir.svc.cluster.local:9001
mimirtool alertmanager load operations/tempo-mixin-compiled/alerts.yaml --address=https://mimir-cluster.distributor.mimir.svc.cluster.local:9001
For Grafana Cloud, you need to add the username and API key as well. Refer to the [mimirtool](/docs/mimir/latest/manage/tools/mimirtool/) documentation for more information.
