Monitor query I/O and span timestamp distance
You can use these metrics to monitor query I/O and span timestamp quality:
tempo_query_frontend_bytes_inspected_totalmeasures how many bytes a query inspects per request type and tenant. This value includes TraceQL metrics queries.tempo_live_store_query_inspected_bytes_totalmeasures how many bytes live-store queries inspect per operation and tenant.tempo_spans_distance_in_future_secondsandtempo_spans_distance_in_past_secondsmeasure how far a span end time is from the ingestion time. This capability lets you find customers that send spans too far in the future or past, which may not be found using the Search API.
Use these metrics together to correlate query cost with data quality and pipeline health.
Reference
The query frontend emits tempo_query_frontend_bytes_inspected_total when a request finishes, aggregating bytes inspected by the query path.
The op label uses traces, search, metadata, or metrics.
The live-store emits tempo_live_store_query_inspected_bytes_total while serving recent data.
Use it to separate recent-data query cost from the total cost reported by the query frontend.
The distributor emits tempo_spans_distance_in_future_seconds and tempo_spans_distance_in_past_seconds by comparing span end time with ingestion time.
PromQL examples
To see how frequently future-dated spans arrive by tenant, use the histogram count rate:
sum by (tenant) (
rate(tempo_spans_distance_in_future_seconds_count[5m])
)Inspect query read throughput (bytes/s) by tenant and operation:
sum by (tenant, op) (
rate(tempo_query_frontend_bytes_inspected_total[5m])
)Inspect recent-data query throughput from live-stores:
rate(tempo_live_store_query_inspected_bytes_total[5m])
)Top five tenants by inspected GiB over the last hour:
topk(
5,
sum by (tenant) (increase(tempo_query_frontend_bytes_inspected_total[1h])) / 1024 / 1024 / 1024
)To quantify ingestion delay using the past-distance histogram, chart the P90 over time:
histogram_quantile(
0.9,
sum by (tenant, le) (
rate(tempo_spans_distance_in_past_seconds_bucket[15m])
