title: "Monitor query I/O and span timestamp distance | Grafana Tempo documentation"
description: "Monitor query I/O and span timestamp quality with key Tempo metrics."
# Monitor query I/O and span timestamp distance
You can use these metrics to monitor query I/O and span timestamp quality:
- `tempo_query_frontend_bytes_inspected_total` measures how many bytes the frontend reads per request type and tenant. This value shows the total number of bytes read from disk and object storage.
- `tempo_spans_distance_in_future_seconds` and `tempo_spans_distance_in_past_seconds` measure how far a span end time is from the ingestion time. This capability lets you find customers that send spans too far in the future or past, which may not be found using the Search API.
Use these metrics together to correlate query cost with data quality and pipeline health.
## Reference
The query frontend emits `tempo_query_frontend_bytes_inspected_total` when a request finishes, aggregating bytes inspected by queriers.
The distributor emits `tempo_spans_distance_in_future_seconds` and `tempo_spans_distance_in_past_seconds` by comparing span end time with ingestion time.
Expand table
| Names        | Type      | Labels         | Buckets                          | Emitted        | Notes        |
| `tempo_query_frontend_bytes_inspected_total`                                     | Counter   | `tenant`, `op` | \-                               | On request completion at the query frontend; aggregates bytes from queriers; excludes cached querier responses. |        |
| `tempo_spans_distance_in_future_seconds`, `tempo_spans_distance_in_past_seconds` | Histogram | `tenant`       | 300s, 1800s, 3600s (5m, 30m, 1h) | In the distributor on ingest; observes seconds between span end time and ingestion time.                        | Spans in the future are accepted but invalid and might not be searchable. |
## PromQL examples
To see how frequently future-dated spans arrive by tenant, use the histogram count rate:
promql ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```promql
sum by (tenant) (
  rate(tempo_spans_distance_in_future_seconds_count[5m])
Inspect query read throughput (`bytes/s`) by tenant and operation:
```promql
sum by (tenant, op) (
  rate(tempo_query_frontend_bytes_inspected_total[5m])
Top five tenants by inspected GiB over the last hour:
```promql
topk(
  5,
  sum by (tenant) (increase(tempo_query_frontend_bytes_inspected_total[1h])) / 1024 / 1024 / 1024
To quantify ingestion delay using the past-distance histogram, chart the P90 over time:
```promql
histogram_quantile(
  0.9,
  sum by (tenant, le) (
    rate(tempo_spans_distance_in_past_seconds_bucket[15m])
