Monitor query I/O and span timestamp distance
You can use these metrics to monitor query I/O and span timestamp quality:
query_frontend_bytes_inspected_totalmeasures how many bytes the frontend reads per request type and tenant. This value shows the total number of bytes read from disk and object storage.spans_distance_in_future_secondsandspans_distance_in_past_secondsmeasure how far a span end time is from the ingestion time. This capability lets you find customers that send spans too far in the future or past, which may not be found using the Search API.
Use these metrics together to correlate query cost with data quality and pipeline health.
Reference
The query frontend emits query_frontend_bytes_inspected_total when a request finishes, aggregating bytes inspected by queriers.
The distributor emits spans_distance_in_future_seconds and spans_distance_in_past_seconds by comparing span end time with ingestion time.
PromQL examples
To see how frequently future-dated spans arrive by tenant, use the histogram count rate:
sum by (tenant) (
rate(tempo_spans_distance_in_future_seconds_count[5m])
)Inspect query read throughput (bytes/s) by tenant and operation:
sum by (tenant, op) (
rate(tempo_query_frontend_bytes_inspected_total[5m])
)Top five tenants by inspected GiB over the last hour:
topk(
5,
sum by (tenant) (increase(tempo_query_frontend_bytes_inspected_total[1h])) / 1024 / 1024 / 1024
)To quantify ingestion delay using the past-distance histogram, chart the P90 over time:
histogram_quantile(
0.9,
sum by (tenant, le) (
rate(tempo_spans_distance_in_past_seconds_bucket[15m])
