This is documentation for the next version of Grafana Tempo documentation. For the latest stable release, go to the latest version.
Reduce cardinality with span name sanitization
Note
span name sanitization is an experimental feature. Engineering and on-call support is not available. Documentation is either limited or not provided outside of code comments. No SLA is provided. Enable the feature toggle in Grafana to use this feature. Do not enable this feature in production environments.
The span_name label often contributes the most to high cardinality in generated metrics.
Applications that embed dynamic values in span names, for example, REST paths with user IDs (GET /users/123) or auto-generated operation names (query-abc-def-ghi), create a unique series for every distinct value.
This drives up active series counts, increases storage and query costs, and can push you past cardinality limits.
You can enable span_name_sanitization to solve this without changing instrumentation across your services.
The option uses the DRAIN algorithm to learn patterns from incoming span names and replace variable segments with a <_> placeholder, reducing many unique span names down to a single representative series.
Use span name sanitization when:
- Your
span_namelabel has high cardinality due to embedded IDs, timestamps, or request parameters. - You don’t control the instrumentation that produces these span names, or changing it across all services isn’t practical.
- You want to reclaim active series budget without losing meaningful aggregation in your span metrics.
Before you begin
- The metrics-generator must be enabled and processing spans.
- You need access to the Tempo configuration or the user-configurable overrides API.
How the DRAIN span name sanitization works
DRAIN is a streaming algorithm that learns patterns from span names as they arrive.
It breaks each span name into tokens (segments separated by delimiters like /, -, or spaces) and organizes them into a tree structure.
When the algorithm sees enough variation at a specific position, for example, numeric IDs, UUIDs, or other data-like values, it replaces that position with a <_> wildcard.
For example, given these span names:
GET /users/123GET /users/456GET /users/789
DRAIN detects that the third token varies while the rest stays constant, and produces the sanitized pattern GET /users/<_>.
All three original span names map to this single pattern in generated metrics.
DRAIN preserves meaningful trailing segments.
For example, given GET /users/123/data and GET /users/123/settings, DRAIN sanitizes the ID but keeps /data and /settings distinct, producing GET /users/<_>/data and GET /users/<_>/settings rather than collapsing both paths into a single pattern.
The algorithm adapts continuously. As new span names arrive, DRAIN refines its patterns and merges additional variable segments. It also prunes stale patterns that haven’t been seen recently.
For more details on the algorithm, refer to Drain: An Online Log Parsing Approach with Fixed Depth Tree (He et al., IEEE ICWS 2017).
Configure the span name sanitizer
Set the span_name_sanitization option in the overrides block of your Tempo configuration:
overrides:
defaults:
metrics_generator:
span_name_sanitization: "enabled"The span_name_sanitization option accepts these values:
You can also set this option per-tenant using the user-configurable overrides API.
Evaluate the impact with dry-run mode
Before enabling span_name_sanitization, use dry_run mode to understand the impact without changing your metrics:
overrides:
defaults:
metrics_generator:
span_name_sanitization: "dry_run"After the model has trained for a few minutes, compare the estimated demand against your current active series:
tempo_metrics_generator_registry_post_sanitization_demand_estimateestimates cardinality if sanitization were fully appliedtempo_metrics_generator_registry_active_seriesshows the current active series count
If the post-sanitization estimate is significantly lower, switching to enabled reduces your active series count.
Monitor the span name sanitizer
After you enable span_name_sanitization, use these metrics to observe its effect:
tempo_metrics_generator_registry_spans_sanitized_totalcounts the spans whosespan_namelabel was replaced by a sanitized patterntempo_metrics_generator_registry_post_sanitization_demand_estimateshows the ongoing cardinality demand after sanitization is applied
Next steps
- Cardinality for background on how cardinality impacts the metrics-generator
- Estimate cardinality from traces to calculate expected active series for service graphs
- Troubleshoot metrics-generator for diagnosing metrics quality issues
