title: "Metadata index | Grafana Pyroscope documentation"
description: "Learn how the Pyroscope v2 metadata index stores and queries block information."
# Metadata index
The metadata index stores information about all data objects (blocks and segments) in object storage. It is maintained by the [metastore](../components/metastore/) service and provides fast lookups for query planning.
## Purpose
The metadata index enables:
- **Block discovery**: Finding blocks that match a query’s time range and filters
- **Query planning**: Identifying exactly which objects need to be read
- **Compaction coordination**: Tracking which blocks can be compacted together
- **Retention enforcement**: Managing block lifecycle and cleanup
## Implementation
The index is implemented using:
- **BoltDB**: Key-value store for metadata entries
- **Raft**: Consensus protocol for replication and consistency
BoltDB was chosen for its simplicity and efficiency with a single writer and concurrent readers. For better performance, the index can be stored on an in-memory volume since it’s recovered from the Raft log on startup.
## Block metadata
Each block in object storage has a corresponding metadata entry containing:
- **Block ID**: Unique identifier (ULID) based on creation time
- **Tenant**: The tenant that owns the data
- **Shard**: The shard assignment for data distribution
- **Time range**: Start and end timestamps of the data
- **Datasets**: Information about contained datasets (services)
### Dataset information
Each dataset within a block includes:
- **Service name**: The `service_name` label identifying the application
- **Labels**: Additional metadata labels for filtering
- **Table of contents**: Offsets to data sections within the dataset
## Index structure
The index is partitioned by time, with each partition covering a 6-hour window:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
Partition (6h window)
├── Tenant A
│   ├── Shard 0
│   ├── Shard 1
│   └── Shard N
└── Tenant B
    ├── Shard 0
    └── Shard N
Within each shard:
- **Block entries**: Key-value pairs (block ID → metadata)
- **String table**: Deduplicated strings for space efficiency
- **Shard index**: Time range for efficient filtering
## Index writes
Index writes are performed by [segment-writers](../components/segment-writer/) when new segments are created:
sequenceDiagram
    participant SW as segment-writer
    participant M as Metastore
    participant R as Raft
    participant I as Index
    SW->>M: AddBlock(metadata)
    M->>R: Propose ADD_BLOCK
    R->>R: Commit to log
    R->>I: Insert block
    I-->>R: Success
    R-->>M: Committed
    M-->>SW: Success
### Tombstone protection
Before adding a block, the index checks for tombstones to prevent re-adding blocks that were already compacted. This handles cases where:
- A writer’s response was lost but the block was added
- The block was already compacted before the retry
## Index queries
Queries use the linearizable read pattern to ensure consistency:
1. **Read index request**: Query asks for the current commit index.
2. **Leader check**: Verifies the current leader.
3. **Wait for commit**: Waits until the commit index is applied locally.
4. **Read state**: Reads from the local state machine.
This allows both leader and follower replicas to serve queries while ensuring they see the latest committed state.
### Query types
The index supports two main query patterns:
**Metadata queries**: Find blocks matching criteria
```none
Query:
  - Time range: [start, end]
  - Tenant: ["tenant-1"]
  - Labels: {service_name="frontend"}
**Label queries**: List available labels without reading data
```none
Query:
  - Return: distinct values for "profile_type" label
  - Filter: {service_name="frontend"}
## Retention
### Compaction-based retention
When blocks are compacted:
1. Source block entries are replaced with compacted block entry.
2. Tombstones are created for source blocks.
3. Tombstones trigger eventual deletion of source objects.
### Time-based retention
Retention policies delete entire partitions based on:
- **Block creation time**: Primary retention criteria
- **Data timestamps**: Blocks are only deleted if data is also past retention
Retention policies are tenant-specific and configurable per tenant.
## Cleanup process
The cleaner runs on the Raft leader and:
1. Lists partitions and applies retention policy.
2. Identifies partitions to delete.
3. Proposes deletion to Raft.
4. Creates tombstones for affected blocks.
5. Tombstones are processed during compaction.
sequenceDiagram
    participant C as Cleaner
    C->>M: TruncateIndex(policy)
    M->>I: List partitions
    I-->>M: Partition list
    M->>M: Apply retention policy
    M->>R: Propose TRUNCATE_INDEX
    R->>I: Delete partitions
    R->>I: Add tombstones
    R-->>M: Committed
    M-->>C: Success
## Performance
### Caching
The index uses several caches:
- **Shard cache**: Keeps shard indexes and string tables in memory
- **Block cache**: Stores decoded metadata entries
### Scalability
- **Storage requirements**: A few gigabytes even at large scale
- **Query performance**: Sub-millisecond lookups with caching
- **Write throughput**: Limited by Raft consensus, typically sufficient for ingestion rates
## Implementation details
For detailed implementation information, including the protobuf schema and internal structures, refer to the [internal documentation](https://github.com/grafana/pyroscope/blob/main/pkg/metastore/index/README.md).
