This is documentation for the next version of Grafana Pyroscope documentation. For the latest stable release, go to the latest version.
Pyroscope v2 deployment modes
Pyroscope v2 can be deployed in different configurations depending on your scale and operational requirements.
Microservices mode
In microservices mode, each component runs as a separate process. This is the recommended deployment for production environments at scale.
Benefits
  • Independent scaling: Scale each component based on its specific load
  • Fault isolation: Component failures don’t affect other components
  • Resource optimization: Allocate resources based on component needs
  • Rolling updates: Update components independently
Components to deploy
ComponentInstancesStatefulNotes
Distributor2+NoScale based on ingestion rate
Segment-writer2+NoScale based on ingestion rate
Metastore3 or 5YesOdd number for Raft consensus
Compaction-worker2+NoScale based on compaction backlog
Query-frontend2+NoScale based on query load
Query-backend2+NoScale based on query load
Object storage requirement
Microservices mode requires object storage (Amazon S3, Google Cloud Storage, Azure Blob Storage, or OpenStack Swift). Local filesystem storage is not supported in this mode.
Single-node mode
For evaluation, development, or small-scale deployments, Pyroscope v2 can run as a single process with all components enabled.
Benefits
  • Simple deployment: Single binary to run
  • Lower resource requirements: Suitable for smaller workloads
  • Local storage option: Can use local filesystem for storage
Limitations
  • No high availability: Single point of failure
  • Limited scalability: Cannot scale individual components
  • Not recommended for production: Use microservices mode for production workloads
Kubernetes deployment
For Kubernetes deployments, use the Helm chart with v2 storage enabled.
Single-binary mode
Bash
helm install pyroscope grafana/pyroscope --version 1.20.3 \
  --set architecture.storage.v1=false \
  --set architecture.storage.v2=true
Microservices mode
Bash
  --set architecture.microservices.enabled=true \
For migrating an existing v1 deployment, refer to the migration guide.
Helm chart considerations
When deploying on Kubernetes:
  • Configure persistent volumes for metastore nodes
  • Set up object storage credentials
  • Configure resource requests and limits for each component
  • Set up ingress for distributor and query-frontend
Storage configuration
Object storage
Pyroscope v2 supports the following object storage backends:
  • Amazon S3: Recommended for AWS deployments
  • Google Cloud Storage: Recommended for GCP deployments
  • Azure Blob Storage: Recommended for Azure deployments
  • OpenStack Swift: For OpenStack environments
Local filesystem
Local filesystem storage is only supported for single-node deployments and is not suitable for production use in microservices mode.
Resource planning
Metastore
The metastore is the only component requiring persistent storage:
  • Disk space: A few gigabytes, even at large scale
  • Memory: Benefits from keeping the index in memory
  • CPU: Moderate usage for Raft consensus operations
Stateless components
All other components are stateless and primarily need:
  • CPU: For data processing
  • Memory: For in-flight data and query execution
  • Network: For object storage access
Object storage
Plan for object storage costs based on:
  • Write operations: Segment flushes and compaction uploads
  • Read operations: Query execution
  • Storage: Retained profile data
To reduce write and read operation costs, refer to the segment-writer configuration for tuning the segment duration, shards per writer, and ingestion consistency.
