title: "Pyroscope v2 deployment modes | Grafana Pyroscope documentation"
description: "Learn about the deployment options for Pyroscope v2."
# Pyroscope v2 deployment modes
Pyroscope v2 can be deployed in different configurations depending on your scale and operational requirements.
## Microservices mode
In microservices mode, each component runs as a separate process. This is the recommended deployment for production environments at scale.
### Benefits
- **Independent scaling**: Scale each component based on its specific load
- **Fault isolation**: Component failures don’t affect other components
- **Resource optimization**: Allocate resources based on component needs
- **Rolling updates**: Update components independently
### Components to deploy
Expand table
| Component         | Instances | Stateful | Notes                             |
| Distributor       | 2+        | No       | Scale based on ingestion rate     |
| Segment-writer    | 2+        | No       | Scale based on ingestion rate     |
| Metastore         | 3 or 5    | Yes      | Odd number for Raft consensus     |
| Compaction-worker | 2+        | No       | Scale based on compaction backlog |
| Query-frontend    | 2+        | No       | Scale based on query load         |
| Query-backend     | 2+        | No       | Scale based on query load         |
### Object storage requirement
Microservices mode requires object storage (Amazon S3, Google Cloud Storage, Azure Blob Storage, or OpenStack Swift). Local filesystem storage is not supported in this mode.
## Single-node mode
For evaluation, development, or small-scale deployments, Pyroscope v2 can run as a single process with all components enabled.
### Benefits
- **Simple deployment**: Single binary to run
- **Lower resource requirements**: Suitable for smaller workloads
- **Local storage option**: Can use local filesystem for storage
### Limitations
- **No high availability**: Single point of failure
- **Limited scalability**: Cannot scale individual components
- **Not recommended for production**: Use microservices mode for production workloads
## Kubernetes deployment
For Kubernetes deployments, use the Helm chart with v2 storage enabled.
### Single-binary mode
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
helm install pyroscope grafana/pyroscope --version 1.20.3 \
  --set architecture.storage.v1=false \
  --set architecture.storage.v2=true
### Microservices mode
```bash
  --set architecture.microservices.enabled=true \
For migrating an existing v1 deployment, refer to the [migration guide](../migrate-from-v1/).
### Helm chart considerations
When deploying on Kubernetes:
- Configure persistent volumes for metastore nodes
- Set up object storage credentials
- Configure resource requests and limits for each component
- Set up ingress for distributor and query-frontend
## Storage configuration
### Object storage
Pyroscope v2 supports the following object storage backends:
- **Amazon S3**: Recommended for AWS deployments
- **Google Cloud Storage**: Recommended for GCP deployments
- **Azure Blob Storage**: Recommended for Azure deployments
- **OpenStack Swift**: For OpenStack environments
### Local filesystem
Local filesystem storage is only supported for single-node deployments and is not suitable for production use in microservices mode.
## Resource planning
### Metastore
The metastore is the only component requiring persistent storage:
- **Disk space**: A few gigabytes, even at large scale
- **Memory**: Benefits from keeping the index in memory
- **CPU**: Moderate usage for Raft consensus operations
### Stateless components
All other components are stateless and primarily need:
- **CPU**: For data processing
- **Memory**: For in-flight data and query execution
- **Network**: For object storage access
### Object storage
Plan for object storage costs based on:
- **Write operations**: Segment flushes and compaction uploads
- **Read operations**: Query execution
- **Storage**: Retained profile data
