title: "Block format | Grafana Pyroscope documentation"
description: "Learn how Pyroscope v2 stores profiling data in object storage."
# Block format
In Pyroscope v2, a block is a single object in object storage (`block.bin`) containing data from one or more *datasets*. Each dataset holds profiling data for a specific service and includes its own TSDB index, symbol data, and profile tables. Block metadata — stored in the [metastore](../components/metastore/) and embedded in the object itself — describes the datasets, their labels, and byte offsets within the object.
## Object storage layout
Segments (level 0, not yet compacted) and compacted blocks are stored in separate top-level directories. Segments are not yet split by tenant and use an anonymous tenant directory. After compaction, blocks are organized by tenant:
![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```none
segments/
  {shard}/
    anonymous/
      {block_id}/
        block.bin
blocks/
  {shard}/
    {tenant}/
      {block_id}/
        block.bin
dlq/
  {shard}/
    {tenant}/
      {block_id}/
        block.bin
## Block structure
Each `block.bin` object contains a sequence of datasets followed by a metadata footer:
```none
Offset    | Content
0         | Dataset 0 data
          | Dataset 1 data
          | Dataset N data
          | Protobuf-encoded block metadata
end-8     | uint32 (big-endian): raw metadata size
end-4     | uint32 (big-endian): CRC32 of metadata + size
## Datasets
A dataset is a self-contained region within the block that stores profiling data for a specific service. Each dataset contains:
- A [TSDB index](https://ganeshvernekar.com/blog/prometheus-tsdb-persistent-block-and-its-index/) mapping series labels to profiles
- Symbol data (`symbols.symdb`) for stack traces and function names
- A [Parquet](https://parquet.apache.org/docs/) table of profile samples
Datasets are annotated with labels (such as `service_name` and `profile_type`) that allow the query path to select only the relevant datasets without reading the entire block.
A separate tenant-wide dataset index allows queries that don’t target a specific service to locate the relevant datasets.
## Block metadata
Block metadata is a protobuf-encoded structure that describes the block’s contents:
- Block ID ([ULID](https://github.com/ulid/spec)), tenant, shard, compaction level, and time range
- A list of datasets with their byte offsets (table of contents), labels, and sizes
- A string table for deduplicating strings across the metadata entry
The metadata is stored both in the [metastore](../components/metastore/) index and embedded in the block object itself.
