title: "Display mode | Grafana Plugins documentation"
description: "Learn about the four available display modes for the Business Variable panel, Table, Minimize, Button, and Slider."
# Display mode
The Business Variable panel enhances dashboard variables by making them more user-friendly. You can place the panel anywhere on the dashboard.
When you configure the Business Variable panel, start with the **Display mode** parameter. This parameter determines the style and available configuration options.
Four options are available for the **Display mode** parameter.
> Note
> The Business Variable panel supports the **Slider** display mode starting from version 3.0.0.
[](/media/docs/grafana/panels-visualizations/business-variable/slider-mode.png)
Follow the links below to learn about each display mode.
Expand table
| Section        | Description                                                    |
| [Table](/docs/plugins/volkovlabs-variable-panel/latest/display-mode/table/)       | From simple lists to elaborated TreeViews                      |
| [Minimize](/docs/plugins/volkovlabs-variable-panel/latest/display-mode/minimize/) | Minimalistic design, similar to the native dashboard variables |
| [Button](/docs/plugins/volkovlabs-variable-panel/latest/display-mode/button/)     | The choice looks like a set of on/off buttons                  |
| [Slider](/docs/plugins/volkovlabs-variable-panel/latest/display-mode/slider/)     | Laconic slider for a simple one-value choice                   |
