title: "Radio group with boolean options | Grafana Plugins documentation"
description: "Learn how to use the radio group form element that provides a choice between True and False values."
# Radio group with boolean options
The **Radio Group with boolean options** provides users with a choice between True and False.
This type doesn’t have any specific options.
## Change elements model
> Note
> Use this model to set elements if you use the [`context.panel.onChangeElements([])`](/docs/plugins/volkovlabs-form-panel/latest/custom-code/context-parameters/#panelonchangeelementsoptions) method.
> Dynamic element creation and manipulation through the panel fetches the complete element model and sets it through a method. The elements aren’t saved in the panel options.
js ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```js
  uid:'',
  title: '',
  type: 'boolean',
  labelWidth: 10,
  width: 30,
  tooltip: '',
  section: '',
  unit: '',
  value: true,
  disabled: false,
  background: '',
  labelBackground:'',
  labelColor: '',
  helpers: {
    showIf: () => true,
    disableIf: () => false,
    getOptions: () => [],
### Code example
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
 * Hardcoded element
const element = {
  uid: "uid-123",
  title: "Element",
  type: "boolean",
  labelWidth: 15,
  width: 150,
  tooltip: "",
  section: "",
  unit: "",
  value: true,
  background: "",
  labelBackground: "",
  labelColor: "",
  helpers: {
    showIf: () => true,
const elementsForUI = [];
elementsForUI.push(element);
context.panel.onChangeElements(elementsForUI);
### Code example with query action for initial request
[](/media/docs/grafana/panels-visualizations/business-forms/query-action.png)
```js
 * Convert JSON to form elements array
const formElements = JSON.parse(
  context.panel.data.series[0].fields[0].values[0]
 * Set elements with helpers
  formElements.map((element) => {
    const elementInForm = context.panel.elements.find(
      (item) => item.uid === element.uid
    let value = element.value;
    if (element.uid === "comment" && elementInForm) {
      value = elementInForm.value;
    return {
      ...element,
      value,
      helpers: {
        showIf: () => true,
        getOptions: () => element.options,
## Element parameters
- ### `value`
  *boolean*. Required.
  Current element value.
- ### `type`
  *string*. Required.
  Element type: ‘boolean’.
<!--THE END-->
- ### `uid`
  *string*. Required.
  A unique identifier used for correct mapping on the UI.
- ### `id`
  *string*. Required.
  The unique identifier of the element.
- ### `title`
  *string*. Required.
  The title or label of the element. Equivalent to the ‘Label’ in the UI editor.
<!--THE END-->
[](/media/docs/grafana/panels-visualizations/business-forms/label-field.png)
- ### `labelWidth`
  *Number* | *null* . Required.
  The element label width.
- ### `width`
  *Number* | *null*. Required.
  The element width.
- ### `tooltip`
  *string*. Required.
  The element tooltip. Leave as an empty string (’’) if not displayed.
- ### `section`
  *string*. Required.
  The unique section identifier (section ID). Specify this if the element is in a section. Leave as an empty string (’’) if the element has no section.
- ### `unit`
  *string*. Required.
  The units of measurement. Located to the right of the element. Leave as an empty string (’’) if the element has no unit.
<!--THE END-->
[](/media/docs/grafana/panels-visualizations/business-forms/unit.png)
- ### `background`
  *string*. Optional.
  The background color as a hex color code.
- ### `labelBackground`
  *string*. Optional. The label background color as a hex color code.
- ### `labelColor`
  *string*. Optional.
  The label color as a hex color code.
- ### `helpers`
  Helpers provide information about the item display or its disabled state and return options.
```js
  showIf: () => true,
  getOptions: () => options || [],
- ### `helpers.showIf`
  *Function*. Required. Returns *true* or *false*. Controls whether the element displays on the UI.
- ### `helpers.disableIf`
  *Function*. Required. Returns *true* or *false*. Controls whether the element is disabled on the UI.
- ### `helpers.getOptions`
  *Function*. Required. Returns an array of options.
  Each option contains the following properties:
  - `value`.
    *string*. Required. The option value.
  - `label`.
    *string*. Required. The option label.
The `Radio Group with boolean options` element does not support options for selection. However, they must be specified in the element object
## Change options model
> Note
> Use this model to set elements if you use the [`context.panel.onOptionsChange({})`](/docs/plugins/volkovlabs-form-panel/latest/custom-code/context-parameters/#panelonoptionschangeoptions) method.
> Elements added through this method are added to the panel options. The element’s operation might not match the expected behavior.
> If you use this method in the initial request, disable the Synchronize option. Enabling the Synchronize option with `context.panel.onOptionsChange()` in the Initial Request causes the panel to reload constantly.
[](/media/docs/grafana/panels-visualizations/business-forms/infinity-reload.png)
```js
  uid:'',
  title: '',
  type: "boolean",
  labelWidth: 10,
  width: 35,
  tooltip: '',
  section: '',
  unit: '',
  value: true,
  showIf: '',
  disableIf: '',
  fieldName: '',
  queryField: {},
  background: '',
  labelBackground:'',
  labelColor: '',
### Code example
```javascript
  ...context.panel.options,
  elements: context.panel.options.elements.map((element) => {
    return element.id === "name" ? { ...element, value: "test" } : element;
```javascript
  elements: formElements,
- ### `value`
- ### `type`
  *string*. Required.
<!--THE END-->
- ### `uid`
  *string*. Required.
- ### `id`
  *string*. Required.
- ### `title`
  *string*. Required.
- ### `labelWidth`
- ### `width`
  The element width.
- ### `tooltip`
  *string*. Required.
- ### `section`
  *string*. Required.
- ### `unit`
  *string*. Required.
- ### `background`
  *string*. Optional.
  *string*. Optional.
- ### `labelColor`
  *string*. Optional.
- ### `showIf`
  *string*. Optional.
  The “Show if” function of the element returns true or false. Controls whether the element displays on the UI.
  ```js
    showIf: "if (condition) {\n  return true\n}\n return false";
- ### `disableIf`
  *string*. Optional.
  The “Disable if” function of the element returns true or false. Controls whether the element is disabled on the UI.
  ```js
    disableIf: "if (condition) {\n  return true\n}\n return false";
- ### `fieldName`
  *string*. Optional.
  The name field from the DataSource initial request. Use for the initial value. We recommend using `value` instead.
- ### `queryField`
  *object*. Optional.
  The name query from the Query initial request. Use for the initial value. We recommend using `value` instead.
  Parameters:
  - `refId`
    *string*. The frame refId.
  - `value`
    *string*. The field name.
  - `label`
    *string*. The format: `refId:value` (for example, `A:time`).
