title: "Dynamic forms | Grafana Plugins documentation"
description: "Learn how to update form elements, values, and options dynamically from any data source using custom code."
# Dynamic forms
You can use custom code to update form elements, values, and options from any data source.
## Select options
The following example defines options for the `icon` element from the `icons` series using the `icon_id` and `title` columns:
js ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```js
const icons = context.panel.data.series.find(
  (serie) => serie.refId === "icons"
const iconSelect = context.panel.elements.find(
  (element) => element.id === "icon"
if (icons?.fields.length) {
  const ids =
    icons.fields.find((f) => f.name === "icon_id").values.buffer ||
    icons.fields.find((f) => f.name === "icon_id").values;
  const titles =
    icons.fields.find((f) => f.name === "title").values.buffer ||
    icons.fields.find((f) => f.name === "title").values;
  iconSelect.options = titles.map((value, index) => {
    return { label: value, value: ids[index] };
context.panel.onOptionsChange(options);
## Update elements from data sources
> Note
> The `context.panel.onOptionsChange()` handler refreshes the panel. If you use this handler in the initial request, disable the **Synchronize with data** option. Using both the **Synchronize with data** option and `context.panel.onOptionsChange()` in the initial request causes the panel to reload continuously.
[](/media/docs/grafana/panels-visualizations/business-forms/infinity-reload.png)
```js
const feedback = context.panel.data.series.find(
  (serie) => serie.refId === "Feedback"
const typeOptions = context.panel.data.series.find(
  (serie) => serie.refId === "Types"
if (feedback?.fields.length) {
  const ids =
    feedback.fields.find((f) => f.name === "id").values.buffer ||
    feedback.fields.find((f) => f.name === "id").values;
  const titles =
    feedback.fields.find((f) => f.name === "title").values.buffer ||
    feedback.fields.find((f) => f.name === "title").values;
  const types =
    feedback.fields.find((f) => f.name === "type").values.buffer ||
    feedback.fields.find((f) => f.name === "type").values;
   * Set Elements
  const elements = ids.map((id, index) => {
    return { id, title: titles[index], type: types[index] };
   * Find Type element
  const typeSelect = elements.find((element) => element.id === "type");
  if (typeSelect && typeOptions?.fields.length) {
    const labels =
      typeOptions.fields.find((f) => f.name === "label").values.buffer ||
      typeOptions.fields.find((f) => f.name === "label").values;
    const values =
      typeOptions.fields.find((f) => f.name === "value").values.buffer ||
      typeOptions.fields.find((f) => f.name === "value").values;
     * Update Types
    typeSelect.options = labels.map((label, index) => {
      return { label, value: values[index] };
   * Update Panel Options
  context.panel.onOptionsChange({ ...context.panel.options, elements });
## Dynamic Business Forms
You can create Business Forms dynamically by using code-specified configuration.
## Sections
> Note
> Starting from version 4.9.0, you can create **Sections** dynamically.
In addition to simple forms, you can create [sections](/docs/plugins/volkovlabs-form-panel/latest/form-elements/#sections) dynamically.
In the following example, the data about required sections comes from the data source. The example uses the [Business Input](/docs/plugins/marcusolsson-static-datasource/latest/) data source to create a basic data frame that contains section information, such as ID and name.
The **Sections** and **Form Elements** categories display as not configured.
In the **Initial Request** category, the **Initial Action** is set to **Code**.
[](/media/docs/grafana/panels-visualizations/business-forms/dyn-sec-how.png)
The JavaScript from the example above:
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
const ids = context.panel.data.series[0].fields[0].values
const names = context.panel.data.series[0].fields[1].values
const sections = ids.map((item, index) => ({
context.panel.sectionsUtils.add({ name: sections[0].name, id: sections[0].id, elements: [] })
context.panel.sectionsUtils.add({ name: sections[1].name, id: sections[1].id, elements: [] })
context.panel.sectionsUtils.add({ name: sections[2].name, id: sections[2].id, elements: [] })
For more available commands and code snippets, refer to the [Context parameters](/docs/plugins/volkovlabs-form-panel/latest/custom-code/context-parameters/) section.
