title: "Custom requests | Grafana Plugins documentation"
description: "Learn how to create custom initial and update requests with custom code for the Business Forms panel."
# Custom requests
You can create custom initial and update requests with custom code.
## Initial request
To create a custom initial request, select `Code` and then define your custom code:
> Note
> The `context.panel.onOptionsChange()` handler refreshes the panel.
> If you use this handler in the initial request, disable the **Synchronize with data** option. Using both the **Synchronize with data** option and `context.panel.onOptionsChange()` in the initial request causes the panel to reload continuously.
[](/media/docs/grafana/panels-visualizations/business-forms/infinity-reload.png)
js ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```js
const bucketsSelect = context.panel.elements.find(
  (element) => element.id === "buckets"
 * Set URL
const url = `http://localhost:3001/test`;
 * Fetch
const resp = fetch(url, {
  method: "GET",
  headers: {
    "Content-Type": "application/json",
    "PRIVATE-TOKEN": "$token",
  .catch((error) => {
    console.error(error);
  .then(async (resp) => {
    const body = await resp.json();
    bucketsSelect.options = body.buckets.map((value) => {
      return { label: value, value };
    context.panel.onOptionsChange(options);
### Initial values
To support the `Highlight changed values` and `Require Confirmation` features, you need to use the `setInitial({})` function within your custom code to update initial values:
```js
context.panel.setInitial({ value: 99, name: "Test" });
## Update request
To create a custom update request, select `Code` and then define your custom code. Depending on the payload option you select, the request includes either all values or only the updated values.
```js
 * Set body
const body = {};
context.panel.options.elements.forEach((element) => {
  if (!options.update.updatedOnly) {
    body[element.id] = element.value;
    return;
   * Skip not updated elements
  if (element.value === initial[element.id]) {
    return;
 * Set URL
const url = `http://localhost:3001/${body["name"]}`;
 * Fetch
  method: "POST",
  headers: {
  body: JSON.stringify(body),
  .catch((error) => {
  .then((resp) => {
    console.log(resp);
