title: "Confirmation window | Grafana Plugins documentation"
description: "Learn how to configure and customize the confirmation window to highlight changes before submitting form updates."
# Confirmation window
When enabled, the confirmation window displays after you click the submit button. It highlights the changes you made in the Business Form.
> Note
> Custom confirmation window labels have been supported starting from version 3.3.0.
You can customize all labels using the **Update Confirmation Window** category.
[](/media/docs/grafana/panels-visualizations/business-forms/confirm-update.png)
## Display Values parameter
> Note
> The **Display Values** parameter is supported starting from version 4.0.0.
The **Display Values** parameter has two options:
- **All values**: Shows all data elements, regardless of whether their values changed.
- **Updated Only**: Shows only the data elements with changed values.
[](/media/docs/grafana/panels-visualizations/business-forms/display-values.png)
