title: "Context parameters | Grafana Plugins documentation"
description: "Learn how to use context parameters to access panel data, form elements, Grafana services, and other functionality in custom code."
# Context parameters
## context.element
Returns the current element.
#### Usage
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
context.element;
#### Example
```javascript
const currentElement = context.element;
## Panel
### panel.data
Returns the result set of panel queries.
#### Usage
```javascript
context.panel.data;
#### Example
```javascript
const data = context.panel.data;
### panel.elements
Returns all form elements.
#### Usage
```javascript
context.panel.elements;
#### Example
```javascript
const currentElements = context.panel.elements;
### panel.initial
Returns the parsed values from the initial request.
#### Usage
```javascript
context.panel.initial;
#### Example
```javascript
const initialValues = context.panel.initial;
### panel.initialRequest()
Performs an initial request to reload the panel.
#### Usage
```javascript
context.panel.initialRequest();
#### Example
```javascript
if (context.panel.response && context.panel.response.ok) {
  context.grafana.notifySuccess(["Update", "Values updated successfully."]);
} else {
  context.grafana.notifyError([
    "Error",
    `An error occurred updating values: ${context.panel.response.status}`,
### panel.options
Returns the panel’s options.
#### Usage
```javascript
context.panel.options;
#### Example
```javascript
const options = context.panel.options;
### panel.onOptionsChange(options)
Modifies the panel options and triggers a refresh. The `context.panel.onOptionsChange()` handler is required to update the panel.
> Note
> The `context.panel.onOptionsChange(options)` handler calls the refresh panel.
> If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with `context.panel.onOptionsChange(options)` in the Initial Request will cause the panel to reload constantly.
#### Usage
```javascript
context.panel.onOptionsChange(options);
#### Example
```javascript
context.panel.onOptionsChange({
  ...context.panel.options,
  elements: context.panel.options.elements.map((element) => {
    return element.id === "name" ? { ...element, value: "test" } : element;
```javascript
  ...options,
  sync: true,
#### Arguments
- `options` *Object*
  Panel options. Use `console.log('options:',context.panel.options)` to check all fields
### panel.onChangeElements(options)
Updates elements in the local state. Accepts an array of new elements.
#### Usage
```javascript
context.panel.onChangeElements(elements);
#### Example
```javascript
  context.panel.elements.map((element) => ({
    ...element,
    value: json[element.id],
```javascript
#### Arguments
- `elements` *Array*
  Array of elements.
### panel.patchFormValue(values)
Updates the values of the specified elements. Accepts an object.
#### Usage
```javascript
context.panel.patchFormValue(elements);
#### Example
```javascript
// only passed elements should be updated, the rest stay the same
context.panel.patchFormValue({ name: "Alex" });
```javascript
// name and isAdmin
context.panel.patchFormValue({ name: "Alex", isAdmin: true });
#### Arguments
- `values` *Object*
  Object. Each key is the `id` of the element and the `value` of the key is the value of the element
### panel.setFormValue(values)
Updates the values of elements. Accepts an object. If a value is not passed for an element, the initial value is used or the value is cleared.
#### Usage
```javascript
context.panel.setFormValue(elements);
#### Example
```javascript
context.panel.setFormValue({ name: "Alex", isAdmin: true });
#### Arguments
- `values` *Object*
### panel.formValue()
Returns the current form values as an object.
#### Usage
```javascript
context.panel.formValue(elements);
#### Example
```javascript
const payload = context.panel.formValue;
// return { name: 'Alex', isAdmin: true }
### panel.response
Returns the current request’s response.
#### Usage
```javascript
context.panel.response;
#### Example
```javascript
  context.grafana.refresh();
} else {
    "Update",
### panel.setInitial(values)
Specifies initial values for a custom initial request to highlight modified values and requests a user’s confirmation.
#### Usage
```javascript
context.panel.setInitial(values);
#### Example
```javascript
// Initial custom code example
const payload = {};
context.panel.elements.forEach((element) => {
  if (!element.value) {
    return;
  payload[element.id] = element.value;
context.panel.setInitial(payload);
return;
#### Arguments
- `values` *Object*
  ```javascript
  // example
    "max": 100,
    "min": 10,
    "speed": 54,
    "option1": "option1",
    "option2": "option1",
    "code": "option1"
## Errors
### panel.setError(message)
Displays an error on panel.
#### Usage
```javascript
context.panel.setError(message);
#### Example
```javascript
context.panel.setError("Message");
[](/media/docs/grafana/panels-visualizations/business-forms/set-error.png)
#### Arguments
- `message` *String*
  Error Message
## Buttons
### panel.enableSubmit()
Enables the Submit button.
#### Usage
```javascript
context.panel.enableSubmit();
#### Example
```javascript
if (condition) {
### panel.disableSubmit()
Disables the Submit button.
#### Usage
```javascript
context.panel.disableSubmit();
#### Example
```javascript
if (condition) {
### panel.enableReset()
Enables the Reset button.
#### Usage
```javascript
context.panel.enableReset();
#### Example
```javascript
if (condition) {
### panel.disableReset()
Disables the Reset button.
#### Usage
```javascript
context.panel.disableReset();
#### Example
```javascript
if (condition) {
### panel.enableSaveDefault()
Enables the Save Default button.
#### Usage
```javascript
context.panel.enableSaveDefault();
#### Example
```javascript
if (condition) {
### panel.disableSaveDefault()
Disables the Save Default button.
#### Usage
```javascript
context.panel.disableSaveDefault();
#### Example
```javascript
if (condition) {
## Sections Utils
### sectionsUtils.add(section)
Adds a new section.
*Added in: v4.9.0*
> Note
> The `context.panel.sectionsUtils.add(section)` handler calls the refresh panel.
> If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with `context.panel.sectionsUtils.add(section)` in the Initial Request will cause the panel to reload constantly.
#### Usage
```javascript
context.panel.sectionsUtils.add(section);
#### Example
```javascript
context.panel.sectionsUtils.add({
  elements: [],
const newSection = {
  elements: ["elem-1", "elem-2"],
context.panel.sectionsUtils.add(newSection);
#### Arguments
- `section` *Object*
  Section. Each section include `name`, `id`, `elements`
#### Common Section properties
- `name` *string*. Section name.
- `id` *string*. Section Id.
- `elements` *Array*. Elements ids assign to section. Could Be empty array.
### sectionsUtils.update(sections)
Updates existing sections.
*Added in: v4.9.0*
> Note
> The `context.panel.sectionsUtils.update(sections)` handler calls the refresh panel.
> If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with `context.panel.sectionsUtils.update(sections)` in the Initial Request will cause the panel to reload constantly.
#### Usage
```javascript
context.panel.sectionsUtils.update(sections);
#### Example
```javascript
context.panel.sectionsUtils.update([{ name: "Section 1", id: "id-s-1" }]);
#### Arguments
- `sections` *Array*
  Sections. Each section include `name` and `id`
### sectionsUtils.remove(id)
Removes a section.
*Added in: v4.9.0*
> Note
> The `context.panel.sectionsUtils.remove(id)` handler calls the refresh panel.
> If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with `context.panel.sectionsUtils.remove(id)` in the Initial Request will cause the panel to reload constantly.
#### Usage
```javascript
context.panel.removeSection(id);
#### Example
```javascript
context.panel.removeSection("id-s-1");
#### Arguments
- `id` *string*. Section id.
### sectionsUtils.assign(id,elements)
Assigns elements to a section.
*Added in: v4.9.0*
> Note
> The `context.panel.sectionsUtils.assign(id,elements)` handler calls the refresh panel.
> If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with `context.panel.sectionsUtils.assign(id,elements)` in the Initial Request will cause the panel to reload constantly.
#### Usage
```javascript
context.panel.sectionsUtils.assign(id, elements);
#### Example
```javascript
context.panel.sectionsUtils.assign("id-s-1", ["elem-1", "elem-2"]);
#### Arguments
- `elements` *Array*. Array of elements ids
### sectionsUtils.unassign(elements)
Unassigns elements from a section.
*Added in: v4.9.0*
> Note
> The `context.panel.sectionsUtils.unassign(elements)` handler calls the refresh panel.
> If you use it in the initial request, don’t forget to disable the Synchronize option. Enabling the Synchronize option and using it together with `context.panel.sectionsUtils.unassign(elements)` in the Initial Request will cause the panel to reload constantly.
#### Usage
```javascript
context.panel.sectionsUtils.unassign(elements);
#### Example
```javascript
context.panel.sectionsUtils.unassign(["elem-1", "elem-2"]);
#### Arguments
### sectionsUtils.get(id)
Returns the section with the specified ID, including all elements assigned to it.
*Added in: v4.9.0*
#### Usage
```javascript
context.panel.sectionsUtils.get(id);
#### Example
```javascript
context.panel.sectionsUtils.get("section-id");
#### Arguments
### sectionsUtils.getAll()
Returns all sections with their assigned elements.
*Added in: v4.9.0*
#### Usage
```javascript
context.panel.sectionsUtils.getAll();
#### Example
```javascript
### sectionsUtils.collapse(id)
Collapses the specified section.
*Updated in: v4.9.0*
#### Usage
```javascript
context.panel.sectionsUtils.collapse(id);
#### Example
```javascript
context.panel.sectionsUtils.collapse("section-id");
#### Arguments
### sectionsUtils.expand(id)
Expands the specified section.
*Added in: v4.9.0*
#### Usage
```javascript
context.panel.sectionsUtils.expand(id);
#### Example
```javascript
context.panel.sectionsUtils.expand("section-id");
#### Arguments
### sectionsUtils.toggle(id)
Toggles the specified section between collapsed and expanded states.
*Added in: v4.9.0*
#### Usage
```javascript
context.panel.sectionsUtils.toggle(id);
#### Example
```javascript
context.panel.sectionsUtils.toggle("section-id");
#### Arguments
### sectionsUtils.expandedState
Returns Expand/Collapse State for Sections.
*Added in: v4.9.0*
#### Usage
```javascript
context.panel.sectionsUtils.expandedState;
#### Example
```javascript
const sectionsExpandedState = context.panel.sectionsUtils.expandedState;
## Grafana
### grafana.locationService
Provides access to Grafana’s `locationService` for working with the browser’s location and history.
#### Usage
```javascript
context.grafana.locationService;
#### Example
```javascript
context.grafana.locationService.reload();
const history = context.grafana.locationService.history;
### grafana.backendService
Provides access to Grafana’s `backendService` for communicating with remote backends such as the Grafana backend or a data source.
#### Usage
```javascript
context.grafana.backendService;
#### Example
```javascript
const deviceID = context.grafana.backendService.deviceID;
### grafana.notifyError(\[header, message])
Displays an error.
#### Usage
```javascript
context.grafana.notifyError([header, message]);
#### Example
```javascript
  "Error",
context.grafana.notifyError(["Error Title", `Show error message`]);
[](/media/docs/grafana/panels-visualizations/business-forms/notify-error.png)
#### Arguments
- `header` *string*. Error title
- `message` *string*. Error message
### grafana.notifySuccess(\[header, message])
Displays a success notification.
#### Usage
```javascript
context.grafana.notifySuccess([header, message]);
#### Example
```javascript
context.grafana.notifySuccess(["Success Title", `Success message`]);
#### Arguments
- `header` *string*. Success title
- `message` *string*. Success message
### grafana.notifyWarning(\[header, message])
Displays a warning.
#### Usage
```javascript
context.grafana.notifyWarning([header, message]);
#### Example
```javascript
context.grafana.notifyWarning(["warning Title", `warning message`]);
#### Arguments
- `header` *string*. Warning title
- `message` *string*. Warning message
### grafana.eventBus
Publish and subscribe to application events.
#### Usage
```javascript
context.grafana.eventBus;
#### Example
```javascript
const subscriber = eventBus.getStream(RefreshEvent).subscribe(() => {
  // to do
### grafana.templateService
Provides access to Grafana’s `templateService` for working with variables and updating the time range.
#### Usage
```javascript
context.grafana.templateService;
#### Example
```javascript
const regEx = context.grafana.templateService.regex;
### grafana.refresh()
Refreshes dashboard panels using application events.
#### Usage
```javascript
## Utils
### utils.fileToBase64(file)
Converts a file to base64 format.
#### Usage
```javascript
context.utils.fileToBase64(file);
#### Example
```javascript
const payload = {};
    return;
 * Data Source payload
const getPayload = async () => {
  const file = payload.file[0];
  const base64 = await context.utils.fileToBase64(file);
  return {
    file,
    base64,
return getPayload();
#### Arguments
- `file` *File*. A File provides information about files.
### utils.toDataQueryResponse(res)
Parses the results from `/api/ds/query` into a `DataQueryResponse` object.
#### Usage
```javascript
context.utils.toDataQueryResponse(res);
#### Example
```javascript
const dataQuery = context.utils.toDataQueryResponse(context.panel.response);
#### Arguments
- `res` *response*. The HTTP response data
