title: "Event handling | Grafana Plugins documentation"
description: "Learn how to handle triggered events in Business Charts including brush events, click interactions, and user interface events."
# Event handling
You can handle specific events while viewing charts, such as mouse events, using the `context.panel.chart` (formerly `echartsInstance`) instance.
For more examples and details, see the Apache ECharts documentation on [Events and Actions](https://apache.github.io/echarts-handbook/en/concepts/event/).
## Mouse click
To prevent the event handling multiple times, all previous event handlers may be disabled.
js ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```js
 * On Mouse Click
context.panel.chart.off("click");
context.panel.chart.on("click", (params) => {
  context.grafana.notifySuccess(["Event", "On Click"]);
  context.panel.chart.resize(); // to redraw visualization
```js
 * On Double Click
context.panel.chart.off("dblclick");
context.panel.chart.on("dblclick", (params) => {
## Update of time range
The Data Zoom feature allows you to select a time period on the chart for zooming in.
Once the time range is selected, the event can trigger the update of the dashboard’s time range using the `context.grafana.locationService` parameter similar to the functionality in native Time Series panel.
[](/media/docs/grafana/panels-visualizations/business-charts/data-zoom.png)
### Example
```js
const series = context.panel.data.series.map((s) => {
  const sData = s.fields.find((f) => f.type === "number").values;
  const sTime = s.fields.find((f) => f.type === "time").values;
  return {
    type: "line",
    showSymbol: false,
    areaStyle: {
      opacity: 0.1,
    lineStyle: {
      width: 1,
    data: sData.map((d, i) => [sTime[i], d.toFixed(2)]),
 * Enable Data Zoom by default
setTimeout(
    context.panel.chart.dispatchAction({
      type: "takeGlobalCursor",
      key: "dataZoomSelect",
      dataZoomSelectActive: true,
  500
 * Update Time Range on Zoom
context.panel.chart.on("datazoom", function (params) {
  const startValue = params.batch[0]?.startValue;
  const endValue = params.batch[0]?.endValue;
  context.grafana.locationService.partial({ from: startValue, to: endValue });
return {
  backgroundColor: "transparent",
  tooltip: {
    trigger: "axis",
  legend: {
    left: "0",
    bottom: "0",
    data: context.panel.data.series.map((s) => s.refId),
    textStyle: {
      color: "rgba(128, 128, 128, .9)",
  toolbox: {
    feature: {
      dataZoom: {
        yAxisIndex: "none",
        icon: {
          zoom: "path://",
          back: "path://",
      saveAsImage: {},
  xAxis: {
    type: "time",
  yAxis: {
    type: "value",
    min: "dataMin",
  grid: {
    left: "2%",
    right: "2%",
    top: "2%",
    bottom: 24,
    containLabel: true,
  series,
