title: "Data sources | Grafana Plugins documentation"
description: "Learn how to use various data sources to query and retrieve data for building charts in the business charts panel."
# Data sources
The Business Charts panel supports various data sources you can use to query data for building charts.
The following code snippet shows how to retrieve data from your data source for use in the Business Charts panel.
JavaScript ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```javascript
context.panel.data.series.map((s) => {
  if (s.refId === "logo") {
    images = s.fields.find((f) => f.name === "body").values;
  } else if (s.refId === "connections") {
    sources = s.fields.find((f) => f.name === "source").values;
    targets = s.fields.find((f) => f.name === "target").values;
  } else if (s.refId === "nodes") {
    titles = s.fields.find((f) => f.name === "title").values;
    descriptions = s.fields.find((f) => f.name === "description").values;
- You can use the `.map()` and `.find()` JavaScript functions.
- The `refId` query retrieves data from a data source. By default, the assigned names look like `A`, `B`, and so on. The code above works with the three queries `logo`, `connections`, and `nodes`.
- `name` is the name of the data frame column. The code above references the `body`, `source`, `target`, `title`, and `description` columns.
- To work with Grafana 9 and its older versions, you need to use the `values.buffer` instead of `values`.
## Array of arrays
You can convert one-dimensional arrays with data into multi-dimensional arrays if needed.
- Fetch values for each field.
- Combine an array into an array of arrays.
- Use as `series[0]` to access the first query, `series[1]` to access the second query, etc.
```javascript
const series = context.panel.data.series.map((s) => {
  const rates = s.fields.find((f) => f.name === "Rate").values;
  const calls = s.fields.find((f) => f.name === "Calls").values;
  const names = s.fields.find((f) => f.name === "Name").values;
  return rates.map((d, i) => [d, calls[i], names[i]]);
})[0];
## Pie chart using visual mode
We use the [Business Input data source](/docs/plugins/marcusolsson-static-datasource/latest/) for this example.
[](/media/docs/grafana/panels-visualizations/business-charts/pie-chart.png)
### Example
js ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```js
return {
  dataset: {
    source: context.editor.dataset.source,
  tooltip: {
    trigger: "item",
  series: [
      type: "pie",
      radius: "80%",
      emphasis: {
        itemStyle: {
          shadowBlur: 10,
          shadowOffsetX: 0,
          shadowColor: "rgba(0, 0, 0, 0.5)",
## Wind speed
The wind speed visualization is one of the advanced examples of what the Business Charts panel can do.
- Every data point is displayed with a custom arrow.
- The arrow color indicates the speed.
- The direction where the arrow points indicates the wind direction.
[](/media/docs/grafana/panels-visualizations/business-charts/wind-speed.png)
### Example
```js
let wind;
  const time = s.fields.find((f) => f.name === "Time").values;
  const value = s.fields.find((f) => f.name === "Speed").values;
  const rotate = s.fields.find((f) => f.name === "Direction").values;
  Set Wind from 3 arrays
  wind = time.map((id, index) => {
    return { symbolRotate: rotate[index], value: [time[index], value[index]] };
return {
  xAxis: {
    type: "time",
  yAxis: {
    type: "value",
  visualMap: {
    orient: "horizontal",
    left: "center",
    min: 0,
    max: 10,
    text: ["High", "Low"],
    dimension: 1,
    inRange: {
      color: ["#65B581", "#FFCE34", "#FD665F"],
  series: [
      data: wind,
      type: "line",
      symbol:
        "path://M31 24.7343L21.7917 24.7343V0L9.20826 0L9.20826 24.7343H0L15.5 45L31 24.7343Z",
      symbolSize: 20,
      lineStyle: {
        width: 0.3,
## Circular graph
We use the [Business Input data source](/plugins/business-input/) for this example.
[](/media/docs/grafana/panels-visualizations/business-charts/circular-graph.png)
### Example
```js
let nodes, links;
 * Data Source data
    var titles = s.fields.find((f) => f.name === "sIp").values;
    var symbolSizes = s.fields.find((f) => f.name === "bytes").values;
    var categories = s.fields.find((f) => f.name === "Count").values;
    nodes = titles.map((title, i) => ({
      symbolSize: symbolSizes[i],
      value: symbolSizes[i],
      category: categories[i],
      label: {
        show: symbolSizes[i] > 1,
  if (s.refId === "links") {
    var sources =
      s.fields.find((f) => f.name === "sIp").values.buffer ||
    var targets =
      s.fields.find((f) => f.name === "dIp").values.buffer ||
      s.fields.find((f) => f.name === "dIp").values;
    links = sources.map((source, i) => ({
      source: source,
      target: targets[i],
 * Categories
const categories = [{ name: "1" }, { name: "2" }, { name: "3" }];
return {
  tooltip: {},
  legend: [
      data: categories.map((a) => a.name),
  animationDurationUpdate: 1500,
  animationEasingUpdate: "quinticInOut",
  series: [
      type: "graph",
      layout: "circular",
      circular: {
        rotateLabel: true,
      data: nodes,
      links: links,
      categories: categories,
      roam: true,
      label: {
        position: "right",
        formatter: "{b}",
      lineStyle: {
        color: "source",
        curveness: 0.3,
