Exploring variables
Variables in Grafana come in three types: dashboard, built-in, and environment. This page breaks them down and shows how they fit into your Grafana deployment.
Three layers of variables in Grafana.
Dashboard variables
Dashboard variables live within a single dashboard, powering filters and dynamic controls. They’re your go-to for tailoring what users see.
Different types of dashboard variables.
Built-in variables
Built-in variables tap into Grafana-wide settings, ready to use across your dashboards. This is a list of the most common ones:
VariableDescription
${__dashboard}Name of the current dashboard
${__from}Start of the time range (epoch ms)
${__interval}Time grouping parameter
${__org.name}Name of the current organization
${__org}ID of the current organization
${__to}End of the time range (epoch ms)
${__user.email}Email of the current user
${__user.id}ID of the current user
${__user.login}Login handle of the current user
For the full list, refer to Grafana built-in variable documentation.
Environment variables
Environment variables pull from the system where Grafana runs (for example, operating system or device settings). Dashboards can’t read them directly by default. To use them, add a data source that exposes environment variables to Grafana.
Variables at a glance
For Business Charts variable substitution in the Charts function, refer to Variables.
