Documentation for automated readers A curated documentation index is available at: https://grafana.com/llms.txt
A complete documentation index is available at: https://grafana.com/llms-full.txt These indexes can help with page discovery before fetching individual documents.
This page is also available in Markdown, which may be easier for automated readers
and AI tools to parse than HTML. The Markdown version is available at
https://grafana.com/docs/plugins/volkovlabs-echarts-panel/latest/exploring-eventbus.md, or by sending
Accept: text/markdown to https://grafana.com/docs/plugins/volkovlabs-echarts-panel/latest/exploring-eventbus/. For broader
documentation discovery, the curated index is available at https://grafana.com/llms.txt
and the complete index is available at https://grafana.com/llms-full.txt.
Grafana leverages an event bus to broadcast application events, enabling different parts of the system to respond when a user interacts with the interface.
This mechanism facilitates real-time communication across components.
Here’s a basic example of subscribing to an event:
The Grafana EventBus supports a variety of predefined events.
Following is a list of key events and their purposes:
Event
Description
absolute-time
Triggered when a user selects an absolute time range on the dashboard
annotation-event
Fired when an annotation is created, updated, or deleted
annotation-query-finished
Occurs after an annotation query completes
annotation-query-started
Occurs when an annotation query begins
copy-panel
Initiated to copy a panel’s JSON to local storage
dashboard-loaded
Fired when a dashboard finishes loading
dashboard-saved
Triggered after a dashboard is saved
data-hover
Occurs when hovering over a legend or data point with shared crosshair enabled
data-hover-clear
Fired when the user stops hovering over a data point with shared crosshair enabled
data-select
Triggered when a user selects a data point on a panel
datasource-updated-successfully
Fired when a data source update succeeds
panel-edit-finished
Occurs when a user finishes editing a panel
panel-edit-started
Triggered when a user begins editing a panel
refresh
Fired when a dashboard is refreshed
render
Occurs when a dashboard is rendered
shift-time
Triggered when the dashboard’s time range shifts
theme-changed
Fired when the theme settings are modified
time-range-updated
Occurs when the time range is updated
variables-changed
Triggered when dashboard variable values change
variables-changed-in-url
Fired when variable values in the URL are updated
variables-time-range-process-done
Occurs when the time range processing for variables completes
zoom-out
Triggered when the user zooms out the time range
The Grafana EventBus is a powerful tool for developers looking to create dynamic, responsive plugins.
By subscribing to predefined events—or even defining your own—you can build interconnected dashboards that react instantly to user actions.
Whether you’re enhancing visualizations or enabling cross-panel communication, mastering the EventBus unlocks a new level of flexibility and control in Grafana development.
